I wanted to create class names using macro. The class are of type uvm_reg and there are 31 such classes named as :
PMT_1, PMT_2 and so on until PMT_31.
The object of teh class is already created in other file where the class is deifned.
I want to just call the class with its read function
For eg:
m_reg. PMT_1. read();
Doing it for all 31 registers is a hectic work.
Trying to use Macro:
`define createPMT(i) PMT_``i
ANd within for loop calling out this macro:
for(int i=0;i<32;i++) begin
m_reg.`createPMT(i).read()
This does not work. Can you please provide a solution to it because I have many classes similar to this.
Could this be done using generate and if yes. HOW?
