Covert array into vector
Problem :
Convert bit[7:0] payload[64] into data[511:0] vector.
I have tried using,
int inx;
foreach(payload[i]) begin
data[((inx+1)8)-1 : inx8] = data[inx];
inx++;
But i am getting compilation issue like :: Range must be bounded by constant expressions.
EDA : Edit code - EDA Playground
In reply to d_g:
https://verificationacademy.com/forums/systemverilog/range-must-be-bounded-constant-expressions#reply-38529
In reply to d_g:
Hi, I did it using shifting . Please go through it and let me know whether it’s ok or not with respect to your requirement.
module x;
  bit [7:0] payload[64];
  bit [511:0] data;
    payload[0] = 2;
    payload[1] = 1;
    foreach(payload[i])
        if(i<=1)continue;
        payload[i] = ((payload[i-1]+payload[i-2])%21==0 ? 1 : (payload[i-1]+payload[i-2])%21); // For getting small numbers (in the range 1 to 20)
    foreach(payload[i])
        $display("%0d",payload[i]);
    $display("\n");
    for(int i=0;i<63;i++) begin
      data = data<<8;
      data [7:0]=payload[i];
      $display("%0d",data[7:0]); // for checking whether it's working or not
     $display("%0b",data);
In reply to d_g:
variable is not allowed to specify width with part-select. Fix your code as suggested above by dave_59.
        data[(i*8)+:8] = payload[i];
You can try packed array also to write simple code.
bit [63:0][7:0] payload;
bit [511:0] data;
  data = payload;
In reply to Alokpati:
Is my observation wrong or missing out on any edge cases ?
