And this covergroup that samples clients and their direction captured, with a bin for each element of client_e in client_cp:
covergroup cg with function sample ( client_e client, dir_e dir );
client_cp : coverpoint client;
dir_cp : coverpoint dir;
client_dir_cr : cross client_cp, dir_cp;
endgroup
I want to create an ignore_bins for the cross that will ignore the bins where client_cp falls within read_only_clients, and dir is WRITE, as these are invalid combinations.
Currently, I have the elements of read_only_clients listed again in the ignore_bins declaration like so:
I’m not happy with this as I need to copy paste this list several times across multiple covergroups. So I’d like to just use the array. I’ve tried doing something like this:
class trans;
typedef enum {CLIENT1, CLIENT2, CLIENT3} client_e;
typedef enum {READ, WRITE} dir_e;
client_e all_clients[] = {CLIENT1, CLIENT2, CLIENT3};
client_e read_only_clients[] = {CLIENT1, CLIENT2};
covergroup cg with function sample(client_e client, dir_e dir);
client_cp: coverpoint client;
dir_cp: coverpoint dir;
client_dir_cr : cross client_cp, dir_cp {
ignore_bins ignore_read_only_clients = client_dir_cr with (client_cp inside {read_only_clients} &&
dir_cp == WRITE);
endgroup
function new();
cg = new;
function run();
foreach(all_clients[i]) begin
cg.sample(all_clients[i], READ);
cg.sample(all_clients[i], WRITE);
trans t = new();
t.run();
Hey Dave, this was my test code I was using on EDAplayground.
After more testing, I decided on a whim to use the Mentor Questa simulator instead of Cadence Xcelium and this solution worked as I expected, as well as my original ignore bins declaration using the “with” clause.
It seems I was having an issue with Xcelium up until now, as that still gives me a “Illegal operand for constant expression” compile error with the same code.
So both of these solutions work in other simulators:
