I was trying to implement a constraint, where I have three rand variables or registers.
If I write a constraint like ‘a-b-c>0’, it gives ‘b’ and ‘c’ values as more than a. If I write the constraint as a>b+c, it works fine.
Is ‘a-b-c>0’ not the correct way to write it?
class a;
rand bit [15:0]a;
rand bit [15:0]b;
rand bit [15:0]c;
constraint c1{
a - b - c > 0;
a a1;
a1 = new();
repeat(10) begin
a1.randomize();
$display("a=%d, b=%d, c=%d", a1.a, a1.b, a1.c);
Link for the code: Constraints_01 - EDA Playground
In reply to Akhil Mehta:
Your problem is a,b, and c are unsigned. Any non-zero result will be greater than 0. I think you want
signed'(a - b - c) > 0;
Even with signed’(a-b-c)>0, I get results as:
a=31441, b=40149, c=35912
a=35754, b=62618, c=12990
a= 688, b= 9979, c=33886
a=14944, b=50266, c= 2779
a=34788, b=60539, c=17031
a=24745, b=49591, c=25592
a=30526, b=51056, c=35862
How are these cases valid? ‘a’ needs to be bigger than both b and c right?
Does compound expressions not work for SV constraints?
Sorry, didn’t notice that a,b, and c were 16 bits. You can do
signed'( 32'( a-b-c ) ) > 0; // or
int'( a-b-c ) > 0;
Thank you Dave, understood :)
