In reply to nhp:
Hi, nhp
Thank you for trying to solve the problem.
But I’m sorry, but there were some missing parts in the example code I posted.
The modified example code is below.
class my_config extends uvm_object;
`uvm_object_util(my_config)
function new(string name = "my_config")
super.new(name);
endfunction : new
int sim_line; // modified
endclass : my_config
class my_test extends uvm_test;
super.build_phase(phase);
env = my_env::type_id::create("env", this);
cfg = my_config::type_id::create("cfg"); // I forgot to write this line, sorry...
cfg.sim_line = 16; // I forgot to write this line, sorry...
uvm_config_db #(my_config)::set(this, "env.agt*", "cfg", cfg);
endfunction : build_phase
endclass : my_test
However, inspired by what you explained, I did some tests, and it seems that my constraint solver problem is related to when the config object was created.
Maybe your approach to the problem will be helpful.
So, I tried to add the line below.
function new(string name = “base_seq”);
super.new(name);
cfg = my_config::type_id::create(“cfg”, null);
endfunction : new
And I got an error below.
Solver failed when solving following set of constraints
integer cfg.sim_line = 0;
rand bit[11:0] line_addr; // rand_mode = ON
constraint line_addr_c // (from this) (constraint_mode = ON) (~path~)
(line_addr < cfg.sim_line);
I think for this error, sim_line = 16 setting was not passed to subsequence.
Thanks.
