How to constraint a random variable defined as rand byte unsigned?
For example, if I want to control the random variable by assigning 0x1 value,
rand byte unsigned data[];
data= 32'h1
Is this the correct way to define it?
data= 32'h1
In reply to basilleaf:
rand byte unsigned data;
constraint c1 {data == 32'h1;}
In reply to Shashank Gurijala:
Your question is not very clear.What does a 0x1 value mean for an array? do you mean each element of tha array to have the value 8’h1? How big is the array?
I want to write specific address with specific value by constraining the seq_item. But Im not sure how to constrain the random variable, data_bytes to have specific value (0x1) since its in bytes unsigned and the source is bit[31:0].
rand longint unsigned address;
rand bit [31:0] len; //Size of the total bytes to be writen or read
rand byte unsigned data_bytes[]; //size of the array shall match the value specified sing ~len~.
`uvm_create_on(seq_item, pick_sqcr("mst_sqr_0"))
seq_item.address = 32'h0100_1220;
seq_item.data_bytes = 32'h1;
start_item(seq_item);
`uvm_info(get_type_name(), $sformatf("Printing seq item"), UVM_NONE);
seq_item.sprint();
finish_item(seq_item);
