class base_b1;
rand bit [31:0] reg_address = 0;
rand bit [31:0] reg_address_array[$];
constraint b1_c {
reg_address dist {5:/25, 10:/25, [25:30]:/50};
constraint size_c2 {
reg_address_array.size inside {[9:10]};
endclass: base_b1
//------------ module top ----------
module tb_top;
base_b1 h_b1;
$display("This is module top !!");
h_b1 = new();
assert(h_b1.randomize());
for (int i=0; i<h_b1.reg_address_array.size(); i++) begin
h_b1.reg_address_array[i] = h_b1.reg_address;
$display("This is base class !! and reg_address is %0d", h_b1.reg_address_array[i]);
I have fill an array with different values, but have to make sure that value 25 and 50 are part of an array. I tried above code but not getting the desired results.
In reply to MarshallX:
You have not connected through any constraint of reg_address to any value in reg_address_array.
The dist construct is not a hard constraint that a value in the set of ranges appear, only that values not in the ranges do not appear.
Maybe this helps
class base_b1;
constraint b1_c {
foreach (reg_address_array[i])
reg_address_array[i] dist {5:/25, 10:/25, [25:50]:/50};
reg_address_array.or() with (item==25); // 25 must appear at least once
reg_address_array.or() with (item==50); // 50 must appear at least once
endclass: base_b1
Maybe this helps
class base_b1;
constraint b1_c {
endclass: base_b1
//--------------- Inheritence Examples ----------
class base_b1;
constraint address_c1 {
reg_address_array[i] dist {5:/25, 10:/25, [25:30]:/50};
reg_address_array.or() with (item == 05);
reg_address_array.or() with (item == 10);
virtual function display_var();
for (int i=0; i<reg_address_array.size(); i++) begin
$display("This is base class !! and reg_address is %0d", reg_address_array[i]);
endfunction: display_var
endclass: base_b1
module tb_top;
//--- handle declaration must be outside "initial begin"
base_b1 h_b1;
h_b1 = new();
h_b1.display_var();
Thanks much dave, the code is working, but have a question why (.or) operation used? The (dist) operator is generating the required values.
The dist operator only gives you a probability of generating the required values, it does not guarantee them. In your example, your gave the value 5 a 25% chance of being picked. That means if you pick 10 values, there is a (.75)10 or 5.6% chance of the value 5 not being picked for any of the array element values. The .or() method forces 5 to be one of the picked values.
Try removing the .or() constraints and randomizing 100 times. (either by using 100 different seeds, or putting randomize in a repeat (100) loop)
