Confusion in fork join ... disable fork
Hello ,
I am unable to get the exact functionality of disable fork.
Example ;
task t1();
    begin : a1
    #1;
    $display("a1");
    begin: a2
    #2;
    $display("a2");
  join_none
    begin : a3
    #5;
    $display("a3");
    begin : a4
    #6;
    $display("a4");
  join_any
  disable fork
    begin : a5
    #5;
    $display("a5");
    begin : a6
    #6;
    $display("a6");
  join_any
Now will this disable fork will disable a1 and a2 also??? Will there be any output in this case??? And, What will happen to a5 and a6???
Hi Anamika,
disable fork statement terminates all active child processes, grandchild processes etc. where it is called.
No, disable fork shall terminate only a3 process because when it is called only a3 process is active.
Both a5 and a6 process shall be continued because disable fork has been executed just before.
The outputs would be:-
a1,
a2,
a3,
a5,
a6
It is best to start from the root thread, which is started by an initial or always block.
initial begin : i1
           fork : f1
              #10 $display("f1")
           join_none
           t1();
The disable fork statements kills the children of the currently running thread. (i.e the thread executing the disable fork statement).
In this example, the parent thread is enclosed by the scope i1. It starts a child thread f1, then calls task t1. Inside task t1, the first fork starts threads a1 and a2, then the second fork starts a3 and a3. Since the second fork has join_any, it waits for one of the threads to complete before executing the disable fork statement.
The disable fork will not execute until thread a3 completes at time 5, and only threads f1 and a4 are still active and will be killed. Had you used join_none instead of join_any, or used longer delays then the disable fork statement would have also killed threads a1, a2 and a3.
The threads a4 and a5 are forked after the disable fork, so it has no effect on those threads.
In reply to RameshRP:
Yes, I said that.
In the example u mentioned above, thread f1 won’t get killed.
Here is what IEEE 1800-2009 std, clause “9.6.3 Disable fork statement”, pg 174 says:
“The disable fork statement terminates all descendants of the calling process as well as
the descendants of the process’s descendants.”
Here is my understanding:
Since calling process i.e. process which called “disable fork” is “t1”, all threads inside t1 and their descendants will get killed. Since thread f1 is not a descendant thread of t1 it should not get killed. I confirmed the same by simulating it w/ VCS too.
Ashish
In reply to AshishP:
Calling a task or function does not create a new process; only a fork can do that. In this case, t1 is a task activation, not new process. So process f1 and a1-a6 are all descendents of the same parent process.
Then is it a bug in VCS since it behaves the way it’s mentioned in comment #6 which doesn’t match w/ what you mentioned in comment #7?
Ashish
Since I work for Mentor, I can comment on Questa’s behavior, and as a member of the IEEE SystemVerilog 1800 committee, I can comment on my interpretation of the LRM, and whether it is correctly worded. In this case, Questa behavior matches my interpretation of the standard, and VCS does not.
Thanks, Dave.
On similar lines, can you explain what should be the ideal behavior for the below code (I was thinking disable fork should disable ff2, please clarify):
class a_bus_monitor;
   bit my_event1;
   int iter;
   task my_monitor();
      fork : ft1
         forever begin:ff1
            #5ns;
            $display("Passed 5 ns now");
            iter++;
            if (iter == 20) begin
               $display("Breaking because iter is 20");
               break;
         forever begin:ff2
            @(my_event1);
            $display("At time %0t found an event on my_event1 (= %0d)",$time,my_event1);
            if (my_event1 == 0) begin
               $display("Disabling fork now");
               disable fork; // ???Should not this disable fork disable ff2???
      join
   endtask:my_monitor;
   a_bus_monitor abm1;
   initial begin: i1
      abm1 = new();
      fork:fm1
         begin:fmf1
            abm1.my_monitor();
         begin:fmf2
            #6ns;
            abm1.my_event1 = 1;
            #10ns;
            abm1.my_event1 = 0;
            #20ns;
            abm1.my_event1 = 1;
            #6ns;
            abm1.my_event1 = 0;
      join
      $display("main fork has been joined");
Questasim 10.3b gives below output:
Passed 5 ns now
At time 6 found an event on my_event1 (= 1)
Passed 5 ns now
Passed 5 ns now
At time 16 found an event on my_event1 (= 0)
Disabling fork now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
At time 36 found an event on my_event1 (= 1)
Passed 5 ns now
At time 42 found an event on my_event1 (= 0)
Disabling fork now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
Passed 5 ns now
In reply to Sailaja:
No.
Your ff2 thread is a single forever statement. You can use the break statement instead to get out of the forever loop.
Got it…
Here in the below code if i get timer_flag as ‘0’ even before the completion of thread named label, I am trying to disable that process. As per my analysis it should disable that particular iteration and again it has to wait for timer_flag to be 1 to continue, and it has to wait for time run_duration before making expired bit 1 from the last valid time_flag that it receives .But this logic is calculating run_duration from the first valid timer_flag.(Consider if re-setting timer_flag to 0 for two times at 0ns, 5ns and 10ns and run_duration value is 50ns,then the expired bit should get assert at 60ns but its happening at 50ns itself,which is not my requirement.) How does it happens even after disabling label thread?
Could you please provide some clarity on this.
Code::
  forever
  begin :label //{
      wait(timer_flag==1);
      #(run_duration);
      expired=1;
      timer_flag=0;
  end //}
  forever
  begin //{
  @(timer_flag);
     if(timer_flag==0)
     ovm_report_info(get_type_name,$psprintf("Disabling label thread at time %.6t", $realtime));
     disable label;
   end //}
 join //}
In reply to sandy1664:
You need to show how you reset the timer flag. If the timer_flag was set to 0 and back to 1 in zero delay, there is no guarantee that the second forever loop would see timer_flag==0 and disable the label
timer_flag = 0;
timer_flag <= 1; // this make sure it is 0 for one delta cycle.
Everytime i reset the timer , the timer_flag becomes 0 and after we start the timer again by making timer_falg to 1 after 1ps delay.
In reply to Sumit Jain:
Hi Sumit ,
please correct me if i am wrong but I believe this code will give output as :-
a1
a2
a3
a5
I tried with Vcs simulator , above is the output i got , I am not seeing any a6 there.
Arpit
For the below example , as main task is calling the dev_state task which contains disable_fork .
Then as per LRM Std 1800-2012 , disable fork will kill all the remaining threads of main task also right .
So the output should be
5 THREAD 1
10 THREAD 3
10 After task call
Could you please let me know whether my understanding is correct
module test;
           main();
task main();
    #5  $display($time,,"THREAD 1");
    #25 $display($time,,"THREAD 2");
  join_any
  dev_state();
  $display($time,,"After task call");
  #100 $finish;
task dev_state();
     #5  $display($time,,"THREAD 3");
     #10 $display($time,,"THREAD 4");
  join_any
  disable fork;
In reply to kvssrohit:
Correct, sort of. It will kill all remaining child threads of the initial block. A task call is not a thread.
Please use code tags to make your code easier to read. I have added them for you.
I wanted to know if a disable fork inside a task can kill threads launched by another task using fork…join_none. For example: In the following code, if task a2() is called 10 units after calling task a1(), will the threads inside a1() be killed?
class alpha;
  task a1();
      #(20) $display("run1");
      #(30) $display("run2");
    join_none
  endtask: a1
  task a2();
    disable fork;
  endtask: a2
endclass: alpha
  alpha abc;
    abc = new();
    abc.a1();
    #(10) abc.a2();
In reply to desaivs1994:
As I said above, Calling a task or function does not create a new thread; only a fork can do that. So whether a disable is “inside” a task has no relevance - it’s the thread that matters.
