I am using the code as follows,
module test(*);
signal_1 = 0;
signal_2 = 0;
// logic ///
`ifndef DATA
signal_1 =100;
signal_2 = 100;
module test(*);
signal_1 = 0;
signal_2 = 0;
// logic ///
`ifndef DATA
signal_1 =100;
signal_2 = 100;
In reply to Sanjeeva Dinesh:
Based on SystemVerilog scheduling semantics, signal_1 can be 0 or 100 which depends on the order of executing.
In reply to javatea:
Thank you for the reply
In my case, it takes 2nd value, i.e which is lastly updated
The code which you mentioned is not good, as it may create a race condition.
Instead, I think below will be good,
`ifndef DATA
signal_1 = 100;
signal_2 = 100;
`else
signal_1 = 0;
signal_2 = 0;
`endif
If you have a situation where you need to do this in 2 separate initial block,
then please add `ifdef for the first initial block also, so that you make sure always one is executed.
`ifdef DATA
signal_1 = 0;
signal_2 = 0;
`endif
`ifndef DATA
signal_1 = 100;
signal_2 = 100;
`endif
Abhi
Verilog does not guarantee the execution order of initial and always blocks. Because of optimizations that a tool performs, it might pick one ordering one time and another ordering in a later version of the same tool.
