According to the LRM, “assign” is a keyword that is used to do “procedural continuous assignments”, this means assignments inside procedural blocks, which behave like continuous assignments: this means the assignment will happen once the right side element changes.
according to what I understood, “assign” can be used only inside procedural blocks. but I have used it outside any procedural block and it worked, I even had an error if I didn’t use it :
module test(.
logic[2:0] a;
logic[15:0] b;
//this raises the error:
// parse error, expecting '(' or IDENTIFIER or INTERFACE_ID near token '='
a = b[14:12];
//this works
assign a = b[14:12];
I don’t know why assign worked in a place where it is not supposed to be used, and I don’t know why my first “normal” continuous assignment raised that error.
There is no such thing a blocking continuous assignment. There are only
procedural blocking assignments
procedural non-blocking assignments
Note that you will rarely see (3) used because synthesis tools choose not to support it. They want procedural code to only have on set of sensitivities.
In reply to Yasmine4:
Yes, my mistake again, I meant to say, why is the normal continuous assignment raising an error that disappears when I use the assign keyword?
