I’m not sure if this is the right place to ask this. Actually, I’m studying the book ‘SystemVerilog for Verification’ by Chris Spear. There is a paragraph explaining the usage of special functions for communication between DUT and TB which lacks examples. Can anyone help me understand how should such a function be written? Here’s the excerpt from the book:
“Lastly, it is a good practice for your testbench to use a function to get
information from the DUT. Reading signal values can work most of the time,
but if the design code changes, your testbench may interpret the values incorrectly.
A function in the module can encapsulate the communication between
the two and make it easier for your testbench to stay synchronized with the
design.”
Thanks in advance
Farhad
In reply to Farhad:
My guess is that a function can encapsulate a set of verification inquiries by poking into variables of several instantiated modules. This encapsulation brings more cohesiveness than putting all that code inline with the verification code. FOr example:
module m(
input bit clk, a,
output bit b);
bit x,w;
module monitor(
input bit clk, a, b);
bit q, w;
timeunit 1ns; timeprecision 100ps;
`include "uvm_macros.svh"
import uvm_pkg::*;
bit clk, a, b, reset_n;
m m1(.*);
monitor mtr1(.*);
function void do_check();
if(m1.x==1'b1) am_xw: assert(mtr1.w==1'b1);
am_w: assert(m1.w==mtr1.q);
repeat (200) begin
@(posedge clk);
do_check();
$finish;
- SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats | Verification Academy
- Free books: Component Design by Example FREE BOOK: Component Design by Example … A Step-by-Step Process Using VHDL with UART as Vehicle | Verification Academy
Real Chip Design and Verification Using Verilog and VHDL($3) Amazon.com - Papers:
- Understanding the SVA Engine,
Verification Horizons - July 2020 | Verification Academy - SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy - SVA in a UVM Class-based Environment
Thank you very much for your comprehensive answer. I got the point. Using the encapsulating functions prevents scattered access to module internals from all over the testbench, thus makes the code more organized and reduces the probability of making mistakes in case the module is modified.
