Hi.
I defined the next macro:
`define CONNECT(ARRAY_NAME, CH)\
assign ARRAY_NAME[CH] = ddr``CH;
if i use it like:
`CONNECT(signal_list, 2)
then every thing is O.K and this macro replaced by:
assign sginal_list[2] = ddr2;
But the problem start when i am using it inside generate:
genvar c;
for (c = 0; c < 2; c = c+1) : test
`CONNECT(signal_list, c)
endgenerate
I get the next code:
assign sginal_list[0] = ddrc;
assign sginal_list[1] = ddrc;
i expect to get ddr0 & ddr1 and not ddrc
Any idea?
Macros are pre-processor compiler directives. That means macros are processed before any Verilog syntax is parsed - before the compile knows about the generate statement.
Your choices are:
- fix the ddrN code to be an array in the first place
- manually write the code
- find another pre-processor that can handle the looping macro code.
Thanks.
I cant change the ddrN to be array (its not my code)
1 can write it manually but its a lot of work.
although Macros are pre-processor compiler directive. surprisingly it did work for the left side.
is there any other way to get the desied code by using system verilog only?
In reply to kobipinhas:
After the macro processing, the generate statement looks like
genvar c;
assign signal_list[c] = ddrc;
There is no way to get this to work within SystemVerilog except by manually writing the code. Perhaps you can use a text editor macro to help you.
