Hey!
I’ve encountered the following phenomena during the tweaking of my design to SV’s clocked interfaces. I’ve reproduced the result in Keisuke Shimizu’s Jelly Bean – UVM based – environment for easier access.
So, to my best knowledge if I declare a clocking block in the following way I should see a skew of the signals at the waveform simulation. But alas, no matter how I specify the parameters, the waveform stays the same. (The change at lines does always happen at the clocking block’s event occurrence.)
Relevant code sections:
interface jelly_bean_if( input bit clk );
wire [2:0] flavor; // All variables are wires.
clocking master_cb @ ( posedge clk );
default input #1step output #3ns;
inout flavor, color, sugar_free, sour;
endclocking: master_cb
modport master_sync_mp ( clocking master_cb );
endinterface: jelly_bean_if
class jelly_bean_driver extends uvm_driver#( jelly_bean_transaction );
`uvm_component_utils( jelly_bean_driver )
virtual jelly_bean_if jb_vi;
jelly_bean_transaction jb_tx;
task run_phase( uvm_phase phase );
forever begin
@jb_vi.master_cb;
jb_vi.master_cb.flavor <= jb_tx.flavor;
end // forever begin
endtask: run_phase
endclass: jelly_bean_driver
This result in QuestaSim 10.2c in the following waveform:
Link if the picture is not working.
I might not be fully aware of the clocking block’s function, but shouldn’t it delay the output on the interface via the defined amount of time?
I’ve found a workaround for this matter also, but I think if the output skew is defined it would be a much better way to handle this matter.
@jb_vi.master_cb;
#2ns;
jb_vi.master_cb.flavor <= 'z;
All help is appreciated.
