Class inside a package
HI,
I would like to get the following clarified:
There is a package inside which a class is defined
file name: packageA.sv
Line 1:
package A;
class xyz;
function1();
function2();
class abc;
function3();
function4();
endpackage
In a class which uses this package, I say:
`include "packageA.sv";
import packageA::*;
  class stim;
     abc obj1;
     obj1 = new();
When I try to compile this , it gives error pointing to packageA.sv (1):
near “package”: syntax error, unexpected package, expecting class.
what is it that is wrong here. Can you please help me out.
In reply to Ramyas:
You should have gotten a nested set of filenames in you error message. What is the name of the file that has the `include “packageA.sv”;, and is that the first line of the file?
Somethat that come before that could be the problem.
Name of the file that has the `include and import of packageA is stim.sv .
I’m not clear about this question : "and is that the first line of the file?2
Somethat that come before that could be the problem. : Thanks for your response, dave. But I’m not sure I get this point.
In reply to Ramyas:
Syntax error messages can be very cryptic. Sometimes there is nothing wrong with the line it is pointing to, but there is a problem with the source text that comes just before it. The pre-processor is just going to inline all the `include files, so think only of the single stream of text that is being compiled.
So I’ll ask again, what source text comes before the `include statement in the stim.sv file?
the stim.sv is compiled separately. As in, in a package , there are a list of files included, one of them is stim.sv: like:
package bus_agent;
include "file1.sv" include “stim.sv”
endpackage
Another thing I tried was : in the above stim.sv file, I removed the import packageA and used only include , like as follows:
class stim;
 abc obj1;
 packageA::obj1 = new();
Now, the error is: packageA.sv(1) near “package”: syntax error, unexpected package, expecting class.
Can a package have a class within it as I’ve shown above and what would be a correct way to include/import packageA in stim.sv. Note: packageA comes from a different directory structure (from another team. This is suposed to be shared). So, I can only include/import packageA and use it.
In reply to Ramyas:
*include "packageA.sv";* I think include should not end with a semicolon. Just remove the semicolon on this line and try again.
In reply to Ramyas:
You’ve nested package declarations. Follow this:
package bus_agent;
`include "file1.sv"
`include "stim.sv"
  // stim.sv does an include of pkgA.sv
  // So a pre-processor ends up with:
  package A; // Syntax error
HTH
Srini
www.go2uvm.org
In reply to NANDA KUMAR:
The semicolon is a typo. thats not present in the actual file.
In reply to Srini @ CVCblr.com:
As I said earlier, packageA is a shared package/file. I have to use it as is. I can only include/import in my files.
In reply to Ramyas:
Move that include stim.sv to outside the package
package bus_agent
Good luck
Srini
In reply to Ramyas:
It might help if you had a clearer picture of the differences between import and `include. See SystemVerilog Coding Guidelines: Package import versus `include - Verification Horizons
