ssakshi
September 6, 2020, 8:43pm
1
I have a doubt in the implementation of the SV checker which checks if a valid request is asserted, there should be a grant after 10 clock cycles.
Code:
always @(posedge req)
@(posedge clk);
fork: req_to_gnt
begin: check_ack
repeat (10) @(posedge clk);
@(posedge gnt)
$display ("SUCCESS: Grant arrived in time ", $time);
disable cntr;
end:check_ack
begin:cntr
repeat(11) @(posedge clk);
$display("ERROR:Grant did not arrive in time\n", $time);
disable check_ack;
end :cntr
join_none
This code is not working for the input requests in two consecutive cycles.
Can someone help with implementing this checker without using SVA?
user49
September 6, 2020, 10:34pm
2
In reply to ssakshi :
See my paper**- Understanding the SVA Engine,**
Verification Horizons - July 2020 | Verification Academy
It addresses in great details how to model SVA using the fork-join_none
The paper will answer your questions. The method you used is close, but you should sample the req and gnt with the clk. Also, make sure the tasks are automatic (they are if in a class).
SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats | Verification Academy
Free books: Component Design by Example FREE BOOK: Component Design by Example … A Step-by-Step Process Using VHDL with UART as Vehicle | Verification Academy
Papers:
ssakshi
September 6, 2020, 10:49pm
3
In reply to ben@SystemVerilog.us :
Thanks!!
