Consider following example. I have such 10 instances in DUT and 50 variables I would like to get in TB. I am trying following generate statement but not working with macro.
module a1();
reg a;
endmodule : a1
module a2();
a1 u_a1();
endmodule : a2
module a3();
a2 u_a2a();
a2 u_a2b();
a2 u_a2c();
endmodule : a3;
module dut();
a3 u_a3();
endmodule : dut
module tb();
// In following, idx needs to be replaced with "a" or "b" or "c"
`define CTRL_REG(idx) dut.u_a3.u_a2``idx``.u_a1
logic a[3];
genvar g;
generate
for(g=0; g<3; g++) begin
assign a[g] = `CTRL_REG(string'(g+97)).a; // This is not working, I want to convert 0 to a (as per instance name)
// How to achieve following using generate statement and macro `define as above
// assign a[0] = dut.u_a3.u_a2a.u_a1.a;
// assign a[1] = dut.u_a3.u_a2b.u_a1.a;
// assign a[2] = dut.u_a3.u_a2c.u_a1.a;
endgenerate
endmodule : tb
Regards,
Nimesh
This cannot be done for 2 reasons. First, macros are preprocessed before any thing else. It will create the following code:
assign a[g] = dut.u_a3.u_a2string'(g+97).u_a1.a;
And u_a2string’(g+97) is not a valid instance path name.
Second, identifiers in SyatemVerilog are symbols, not strings that can be manipulated.
So there is no otherway to reduce or atutomate this code?? At present, I used in-line mux to keep moving…
Kindly suggest, if there is someway to handle this.
Thanks for your response, Dave…!!
Regards,
Nimesh
In reply to Nimesh Patel - eInfochips, Inc:
Hi Nimesh,
What you’re trying to do using a string is rather hard due to limitations in the language. However, there is a way to automate your instantiations if you use an array of instances. Here’s what you do:
(1) Change your a3 module to this:
module a3;
a2 u_a2 [2:0] ();
This causes your a2 module to be instantiated 3 times.
(2) Then, using your genvar variable, g, index the instances:
module tb();
logic a[3];
genvar g;
generate
assign a[g] = dut.u_a3.u_a2[g].u_a1.a;
endgenerate
endmodule : tb
That should do it.
Good luck!
-Doug
