I am facing this issue where I need to verify the functionality of an AHB-to-AXI4 bridge and I want to check if the WLAST is properly set using SVAs.
Ultimately, what I want to check in boolean algebra is:
AWVALID && AWREADY → (
(##some-initial-delay0 WVALID && WREADY → !WLAST) and
(##longer-delay-after-delay0 WVALID && WREADY → WLAST)
How can I achieve the same semantics using SV assert property constructs?
I tried the following:
assert property(
@(posedge clk) disable iff (!rst_n)
axi4_o.aw.valid && axi4_i.aw.ready
|-> (##[1:100] (axi4_o.w.valid && axi4_i.w.ready) |-> !axi4_o.w.last)
##0
(##[1:100] (axi4_o.w.valid && axi4_i.w.ready) |-> axi4_o.w.last)
but this does not work since the operand of ##0 must be a sequence not a property and the result of “|->“ is a property.
I ended up later with something like this:
assert_w4: assert property(
|-> ##[1:100]((!axi4_o.w.last) throughout (axi4_o.w.valid && axi4_i.w.ready))
##[1:100]((axi4_o.w.last) throughout (axi4_o.w.valid && axi4_i.w.ready))
But I am not sure if it is equivalent to the intended logic. Any help would be appreciated.
M.E.
