Can we randomize strings in systemverilog
Can we randomize strings in systemverilog ? for example the below code is giving me the following error :-
 class chk;
   rand string abc;
module pg;
  chk c1;
    c1=new();
    c1.randomize();
    $display("%s \n",c1.abc);
    $finish;
Errors:
cvlog: *E,RNDVBL (testbench.sv,4|17): Variables declared with the 'rand' modifier must be of an integral or class handle type
In reply to dhpant28:
No, we cannot randomize a string variable. Here is a workaround that I could come up with for generating random strings.
class temp_c;
    rand byte unsigned temp[];
    constraint str_len { temp.size() == 4; } // Length of the string
    constraint temp_str_ascii { foreach(temp[i]) temp[i] inside {[65:90], [97:122]}; } //To restrict between 'A-Z' and 'a-z'
    function string get_str();
        string str;
        foreach(temp[i])
            str = {str, string'(temp[i])};
        return str;
   temp_c obj;
       obj = new;
       obj.randomize();
       $display("\nString is :%0s", obj.get_str());
In reply to sharat:
thanks got it :)
In reply to sharat:
Thanks for this Code. I have one question regarding the array declaration. Over here we have made some conditions upon the numbers which are unsigned themselves. So, do we need to specify
" unsigned ". Can we not just write -
rand byte str [];
constraint condition{str.size <= 50;
                     foreach(str[i])
                       str[i] inside {[65:90], [97:122]};}
In reply to Shubhabrata:
For this example, it doesn’t matter. But if the constraints involved numbers bigger than 127, they would be treated as negative.
You can use packed vectors of 8 bits.
For example, this is a program that generate a palindrome of length 10 characters. Using constrained randomization:
module testb;
  class tb;
    rand bit [10][8] palindrome;
    constraint palindrome_constr {
      foreach(palindrome[i]) {
        palindrome[i] inside {[65:90], [97:122]};
        if(i<10/2){
          palindrome[i] == palindrome[10-i-1];
        else {
                    tb tb_object;
                             tb_object = new();
                             repeat(10) begin
                               assert(tb_object.randomize());
                               $display("%s", tb_object.palindrome);
