Hi All,
Curious to know how subroutine execute on sequence match, I have been referring to section 16.11 of the LRM.
I have been trying out various examples to understand their working in terms of SV region.
Having established a decent knowledge of it, I am trying to confirm whether my understanding is correct
bit clk , a , b , c ;
bit [3:0] length , len ;
always #5 clk = !clk;
// 'Length1' could be declared as Non-blocking task as well
function void Length1( input bit [3:0] L ); // Executes in Reactive region
length = L ;
$display("Assigned length == %0d",L);
function bit[3:0] Length2(); // Executes in Observed region prior to 'Length1' !!
$display("Length is %0d",length);
return length ;
sequence seq;
bit [3:0] data , data2 ;
@(posedge clk) (1, data = len , Length1(data) , data2 = Length2() , $display("data2 is %0d",data2) );
endsequence
assert property( seq ) $display("Assertion Pass"); // Action block executes in Reactive region
#04 ; len = 10 ;
#2 ; $finish();
Here is what the LRM mentions
[1] LRM 16.10 Local variables
- Initialization assignments shall be performed in the Observed region in the order that they appear in the sequence or property declaration
[2] LRM 16.11
- Tasks, task methods, void functions, void function methods, and system tasks can be called at the end of a successful nonempty match of a sequence.
- All subroutine calls attached to a sequence are executed at every end point of the sequence.
For each endpoint, the attached calls are executed in the order they appear in the list. - Assertion evaluation does not wait on or receive data back from any attached subroutine.
- The subroutines are scheduled in the Reactive region, like an action block.
Here is my interpretation of the LRM w.r.t above code ::
(a) Local variables ‘data’ , ‘data2’ are assigned in Observed region.
The assignment occurs in the order of declaration i.e data is assigned first followed by data2
At T:5, data is assigned value of 10 ( len )
(b) Void function / task / system task ( eg: $display() ) execute in Reactive region similar to action block.
The LRM doesn’t define the order of execution between $display within ‘Length1’ and $display within action block
However as per 2 , LRM does define the order of execution between function ‘Length1’ and system task: $display(“data2 is %0d”,data2)
As ‘Length1’ appears first, it executes before system task: $display(“data2 is %0d”,data2)
Function ‘Length1’ executes in Reactive region where it assigns length = 10.
(c) As function ‘Length2’ has a return value which is used for local variable initialization, function ‘Length2’ executes in Observed region ( due to 1 )
Based on above points here is my expected output :
Length is 0 // Executes in Observed region as 'Length2' executes in Observed region
Assertion Pass // Executes in Reactive region
Assigned length == 10 // Void function 'Length1' executes in Reactive region
data2 is 0 // System task executes in Reactive region AFTER 'Length1'
Local variable **'data2' is assigned 0 as void function 'Length1' is yet to execute later in Reactive region whereas 'data2' is assigned in Observed region.**
The "Assertion Pass" report can execute last as well as the LRM doesn't define the exact order of execution ( Refer (b) above )
So the following output is legal as well
Length is 0
data2 is 0
Assertion Pass // May execute last as well
