I wish to know whether we can call a test(which is a “module” in a sv file)for execution inside the testbench file (which is a verilog file) ?
Thanks in advance!
Thanks in advance!
In reply to Saraswati:
Your question is not very clear. You never call modules for execution; you instantiate modules inside of other modules.
Maybe you are asking if you can instantiate a module compiled in SystemVerilog inside a module restricted to Verilog-only. The answer that is yes; as long as the port data-types of the SystemVerilog module are assignment compatible with Verilog data types.
Thanks for your answer, and by instantiating the module in another module, whatever is inside the module would execute right ?
Thanks!
