In reply to svishnu:
The two examples you show are functionally the same, and there is no need for a for-loop. You could have written it as
logic [NUM+1:1] c;
logic [NUM:0] a,b;
always_comb c = a | b;
If you had the code
always_comb begin
c <= a | b;
d <= c + 1;
Now there is a significant difference in that second statement would be using the previous value of c, which no longer represents combinational logic and would be flagged as an error.
For this reason, you should never use non-blocking assignments in an always_comb block.
For your code, synthesized structure should be same for both the cases. But, as Dave explained you should not use non-blocking assignment to create combinational logic. And if you do, that might infer unintetional latch.
