Dear Forum,
Please help to make the TB to DUT connection using bind command.
So this is my Top DUT:
module dut_top(
input FPGA_CLK100M_P,
input FPGA_CLK100M_N,
input LOGIC_RESETn, // Active LOW !!!
input CLOCK_PRESENT
wire fifo_in, fifo_out;
fifo u_TIFIFO (
.in_dut(fifo_in),
.out_dut(fifo_out)
My test-bench only needs to be connected to u_TIFIFO instance of the RTL top.
This is how the interface looks like:
interface itf (
output reg fifo_in,
input fifo_out
endinterface
And the top module
module top();
wire in,out;
dut_top dutInst ();
itf itfInstncTI (in, out);
tb tbInst (itfInstncTI ); // here TB drives all the interface signal
bindModule bindInst(in, out);
The issue is that I cannot write the binding module. I cannot specify the instance of interface in the bind command
module bindModule(input in, output out);
// for TIFIFO
bind fifo:top.dutInst.u_TIFIFO itf bindInst (
.fifo_in(in_dut),
.fifo_out(out_dut)
Seems there is no way to bind the interface instance to another instance of RTL top module.
Could you please provide some suggestions how I can resolve this issue.
