Hi All,
I am teaching myself SystemVerilog and starting with a simple module and hope to add to it as a way to learn this program. I’m trying to make an LED blink for 0.5 secs (I just randomly chose this). For some reason, my LED (named state) stays OFF. Why is it always OFF?
***** FYI: I was told to make the Counter and the State (different from my LED called “state”) in separate always blocks so that I can have a better understanding of how they work in parallel.*****
Here is the code I have so far and I’m not sure what else to try changing. I put comments in so you understand my reasoning. Any input is much appreciated! Thank you!
module Blink
input logic Clock_50, //I'm using a 50MHz clock --> T = 20ns
output logic state = 1'b0 //LED state starts in OFF position
//Define counter
logic [24:0] counter = 25'b0; //25 counters that hold 25 bits that are currently set
//to zero? Right?
//Create counter:
always_ff @ (posedge Clock_50) //at every pos clk edgd
begin //begin counting
counter[24:0] <= counter[24:0] + 25'b1; //cnt = cnt + 1 (started counting)
if (counter[24:0] == 25'd25000000) //if counter = 25,000,000 (the cycles needed
begin //for a 0.5 sec blink)
counter[24:0] <= 25'0; //reset counter to zero
counter[24:0] <= counter[24:0] + 25'b1; //else, keep counting
//Create State:
always_ff @ (posedge Clock_50) //change at positive clk edge
if (counter[24:0] == 25'd25000000) //counter reaches 25,000,000
state <= 1'b1; //state is ON (it's connected to an LED)
state <= 1'b0; //state is OFF (it is ALWAYS OFF... \_o_/ ???????)
