Asyncronous rst coding in SV
What is the best way to code a configurable asyncronous rst in SV ?
As it is a configurable rst it’s hard to use the posedge and negedge constructs.
c_act_rst <= 1'b0; // means i_rst is active LOW
c_act_rst <= 1'b1; // means i_rst is active HIGH
Is this the best way? :
    always_ff @(posedge i_clk or i_rst==c_act_rst)
        if (i_rst==c_act_rst)
            // signal rst behav
            // signal clocked behav
Thanx for the feedback you can provide!
In reply to stefaniecg:
i_rst is main reset signal?
c_act_rst is configurable reset signal (soft reset)?
Why don’t you use:
    wire rst_tmp = i_rst | c_act_rst; // assert at high level.
    always_ff @(posedge i_clk or posedge rst_tmp)
        if (rst_tmp)
            // signal rst behav
In design, we need to synchronize deasserted-reset signal to clock.
In reply to cuonghl:
Hey @cuonghle !
Thanx for your reply!
i_rst is the main reset signal (that is correct), but what I mean with c_act_rst is the polarity of the active reset, meaning:
c_act_rst <= 1'b0; // means reset is active LOW
c_act_rst <= 1'b1; // means reset is active HIGH
c_act_rst is a static parameter defined at compile time, i.e. is a constant.
You meant, c_act_rst is a constaint that decide which active level of i_rst (main rst)?
  • c_act_rst = 1’b0: then i_rst will active LOW
  • c_act_rst = 1’b1: then i_rst will active HIGH
If so, can you try:
   wire rst_tmp = (!c_act_rst) ? ~i_rst : i_rst;
        if (rst_tmp)
            // signal rst behav
Thanx Chris (@cuonghle) !
I think that is a better way to code it :)
