This is a very long list.
What I would like to do is put it in a loop but the the problem is how do I substitute the loop variable into assign FRED_0_CH etc?
Ye rohitk, that is exactly what I want to do. Somebody has suggested to me that the answer MAY lie in using $sformatf. So that code fragment won’t work will it?
The code Rohit shows will not work. The left hand side of the expression needs to be a static identifier at compile time. So the only sort of changes you can make would be with pre-processor compiler directives that get evaluated before compile. Unfortunately the SV pre-processor doesn’t have a looping mechanism
If the FRED_X_CH signals truly need to be their own independent signals as not an array themselves as Anudeep suggests, they will need to be written out separately
I tried to use a similar macro inside a generate statement, but since generate statements are processed at elaboration time (i.e after macro processing), the logic didn’t work. Is there a way to get the generate statement unrolled before macro processing or something on those lines?
In reply to Srini @ CVCblr.com:
Sharat,
That would require language extension like what I’ve suggested at the end of my previous post.
