Assertion to check x or z when signal toggles instead of every clock tick
I am trying to write an assertion that won’t burden the simulator while checking for x or z on 1000’s of signals. So instead of checking at every posedge of clock I am checking whenever the signal changes.
The following is the code snippet. The expectation is that assertion should fail when there is a transition from 0/1 to x. But the assertion passes.
module output_x_assertion (
	input signal1
property x_prop_on_d;
    @ (signal1)
    $changed(signal1) |-> (!$isunknown(signal1));
  x_prop_on_d_assert : assert property (x_prop_on_d)
      `uvm_info("USER_NONX_ASSERT", $psprintf("No X on Signal"), UVM_LOW)
  else begin
      `uvm_error("USER_NONX_ASSERT","unknown on d")
Can you let me know where I am going wrong?
Thanks.
In reply to Dilsya:
The issue you have with **assert property (@(a)!$isunknown(a))**is that “a” is sampled in the Preponed Region when “a” changes. Thus, if “a” goes from “1” to “X”, the sampling value is a “1” and thus $isunknown is false. You need the sampling to be in the Active Region.
Use the always with an immediate assertion.
  logic a=1'bX;
  event e;
  always @(a) begin
    $display("%t change in a", $realtime);
    a_unknown: assert (!$isunknown(a)) else  $display("%t Is unknown in a", $realtime);
    -> e;
 // "a" is sampled in the Preponed Region!
  x_prop_on_d_assert : assert property (@(a)!$isunknown(a)) else $display("%t proprIs unknown in a", $realtime);;
    a=1'bX;
    #20 a=1;
    #20 a=1'bZ;
    #20 a=0;
    #20 a=1'bX;
    #20 a=0;
    #20 a=1;
    #20 a=0;
    #30;
                  20 change in a
#                   20 proprIs unknown in a
#                   40 change in a
#                   40 Is unknown in a
#                   60 change in a
#                   60 proprIs unknown in a
#                   80 change in a
#                   80 Is unknown in a
#                  100 change in a
#                  100 proprIs unknown in a
#                  120 change in a
#                  140 change in a
  3. Papers:
Hello Ben, just wondering if the following solution is a valid way of combatting this preponed sampling in a property based assertion (for this application). In this solution the signal is delayed and used for the activation of the property and $isunknown is called on the original signal. Thus, the signal has transitioned and is the desired value when it is sampled.
Code
Waveform
Saw the code.
That would work simce the clocking event occurs 1ps after the evaluation of the signal.
