Assertion to check variable distance of two signals
I’d like to write an assertion to check the distance between two signals like the following.
//              len > 0
//             _________
// s1    :  __|<-------> __
// s2    :     _________|
// v_cnt :     1 2 . .len len
property p_inter_pos_length(s1, s2, len);
  int v_cnt = 0;
  $rose(s1) ##0 first_match( (s1 && !s2, v_cnt++)[*1:$] ##1 s2 ) |-> (v_cnt == len);
However, this doesn’t work with len==0. The situation of $rose(s1) ##0 $rose(s2) with len==0 is also valid. So, I’d like to include len==0 case to the property. Variable wait sequence in stead of variable s1 continuation like the following might be considered.
$rose(s1) ##0 first_match( (1,v_cnt++)[*0:$] ##0 s2) )
But no s2 rising edge after s1 rising edge is possible.
         ____________       __________
s1  : __|            |_____|
                                        __
s2  : _________________________________|
So, I don’t think the idea of variable wait above is applicable.
Does anyone have any good property ideas to resolve this matter in this situation?
Try ::
// Consequent has implicit first_match
property p_inter_pos_length;
 realtime t1,t2;
 ($rose(s1),t1=$realtime) |-> ($fell(s1)[->1]) or (($rose(s2)[->1],t2=$realtime) ##0 ( (t2-t1) > 0 ));
ap1:assert property( @(posedge clk) p_inter_pos_length ) <pass> else <fail>
What is the intention in following case ::
After 1st assertion of s1 (0->1), s1 is de-asserted (1->0) at the same time as s2 is asserted (0->1) ?
Using the above code the assertion would pass due to ‘or’ at de-assertion of s1
Thank you for your proposal. But it looks the property you proposed is different from what I want to check. What I want to check is
“whether the clock cycle number between rising edges of two signals is same as the specified value.”
No, s1 is kept high when s2 is asserted(0->1). But this s1 behavior is not quite related to this matter. The point is how to count cycle number before s2 assert(0->1).
I hit upon the following property idea.
//               len >=0
//              ______________
// s1    :   __|<---------> __
// s2    :      ___________|
// v_cnt :   -1 0 1 2 3 . .len len
//int v_cnt = 0;
//        $rose(s1) ##0 first_match( (s1 && !s2, v_cnt++)[*1:$] ##1 s2 ) |-> (v_cnt == len);
  int v_cnt = -1;
  !s1 ##1 $rose(s1) ##0 first_match( (s1       , v_cnt++)[*1:$] ##0 s2 ) |=> (v_cnt == len);
I think this would work.
If you insist on using a counter approach I would suggest a few changes to your code
  1. Using !s1 ##1 $rose(s1) , is it necessary for s1 to be low in the start ?
    What if you simply used $rose(s1) instead ?
  1. Any particular reason you have used non-overlapping implication operator |=> ?
    When the antecedent has a match, you could check the consequent at the same clock using |->
Here is my attempt using counter logic :: edalink
Thank you for your suggestion.
The reason why I used 1. !s1 ##1 $rose(s1) and 2 . |=> is similar. I just wanted
to separate internal counter increment cycle from counter initialization cycle and check cycle. By 1, I wanted to clarify counter initialization and counter increment are done in a different cycle. By 2, the check is done after the last counter increment cycle. They are only for safety just in case. A property without them would properly work as you have attempted in EDA Playground.
//int v_cnt = 0;
  int v_cnt = -1;
//!s1 ##1 $rose(s1) ##0 first_match( (s1       , v_cnt++)[*1:$] ##0 s2 ) |=> (v_cnt == len);
          $rose(s1) ##0 first_match( (s1       , v_cnt++)[*1:$] ##0 s2 ) |-> (v_cnt == len);
In that case, the internal counter would work like below.
//              ______________
// v_cnt :     -1
//              0 1 2 3 . .len
Another idea.
If you don’t like to initialize v_cnt with -1, then, the following is fine.
//              ______________
// v_cnt :      0
//              1 2 3 . .len len
  int v_cnt = 0;
  $rose(s1) ##0 first_match( (s1, v_cnt += !s2)[*1:$] ##0 s2 ) |-> (v_cnt == len);
v_cnt is incremented only when s2 is low while s1 is high. So, v_cnt is not incremented at the last cycle.
Here is a link to EDA Playground.
EDA Playground : SVA Dynamic Variable Signal Distance Check
There is a large number of experts who abhor the use of the first_match
because of efficiency; also, it is not used in PSL.
Below is another option without the first_match.
I like the v_cnt += !s2
//              ______________
// v_cnt :      0
//              1 2 3 . .len len
  int v_cnt = 0;
  // $rose(s1) ##0 first_match( (s1, v_cnt += !s2)[*1:$] ##0 s2 ) |-> (v_cnt == len);
  ($rose(s1) ##0 (s1, v_cnt += !s2)[*1:$]) intersect s2[->1] |-> (v_cnt == len);
Ben@systemverilog.us
Thanks, Ben,
I will replace first_match with intersect s2[->1].
But note that a certain license free simulator doesn’t properly work with intersect s2[->1] while first_match usage is O.K . It is simulator’s issue, though.
Hello. Can anyone let me know what this expression
(s1, v_cnt += !s2)
exactly does? I was able to understand that increment count till s2 becomes high. But why are we checking on s1?
Hi @Kushal_Nijalingappa ,
It means “v_cnt is incremented while s1 is 1 except s2 is 1”.
I wanted to check the distance between s1 rise and s2 rise. So, the condition of s1 == 1 is necessary. Otherwise, the following distance would also be checked with (1, v_cnt += !s2)
//         _____________      _______________
//s1  : __|^           |_____|             __
//s2  : __________________________________|*
