If I try to use if @bus disable (disable_flag) $past(bus== A) → (bus ==B) & (strobe ==1). It does not work. It does not even evaluate first transition of bus for A to C.
In reply to shals:
Your requirements are not clear.
let A=2'b10; let B=2'b11;
ap_strobe: assert property(@(posedge clk) strobe |-> $past(bus== A) && (bus ==B) );
/* above says that
when strobe==1, current value of bus==A, and past value of bus as B
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
- SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy - SVA: Package for dynamic and range delays and repeats | Verification Academy
- SVA in a UVM Class-based Environment
Hi Ben,
I am sorry for not being very clear.Here are the requirements.
- Bus should change its value when strobe is high. Else assertion should generate error.
- When strobe is high , if bus changes 2’b00 to 2’b10 it is valid. But if it changes to any other value assertion should generate error.
Shals
In reply to shals:
Hi Ben,
Shals
let A=2'b00; let B=2'b10;
$changed(bus) && $past(bus== A) && (bus ==B));
/* above says that
when strobe==1, bus changes its value. Also, the current value of bus==B, and past value of bus was A
Ben SystemVerilog.us
Hi Ben,
Thanks. I did not know about $changed option. That worked. I could use
$changed(bus) && $past(bus== A) |-> (strobe ==1) && (bus ==B));
By the way, I have your book and Appendix-C does list $changed :-)
