Assertion to check if A does not rise between pulse B and Pulse C
Signal B pulse should be followed by Signal C pulse, with no fixed clock cycles between them. Pulse A should not fall between these two pulses(B and C). It be either before B or after C.
How would you write an assertion to check this?
If the tool supports reject_on, you could do something like the following. Thus, if a==0 between b and c, the assertion fails. Code was tested with this quick and dirty testbench
module pulse;
	bit a, a1, b, c, c1;
	// Signal B pulse should be followed by Signal C pulse, with no fixed clock cycles between them.
	// Pulse A should not fall between these two pulses(B and C). It be either before B or after C.
    ap_abc: assert property(reject_on (!a)
		  @(posedge b) 1'b1 |-> @(posedge c) 1'b1);
    initial repeat(2000)
	     #10;
	     if (!randomize(a1, b, c1) with
	     		{a1 dist {1:=10, 0:=1};}) $display("error");
	     #1 c=c1;
	     #2 a=a1;
The reject_on (expression_or_dist) property_expr rejects the property as false if the abort condition is true. Otherwise, with the abort condition as false, the property expression evaluates to completion. The abort condition with the reject_on is asynchronous, whereas the sync_ reject_on is synchronous to the clock under current consideration for the property.
  • SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
Hi Ben,
   If in between B and C there may be any number of clock cycles like [1:$] in a given simulation but A should not be become high in between B and C.
In that case how your code looks like?
Regarding “reject_on”
I don’t know about this.As per our requirement we should reject property when A is high right ?
in that why you have written like "assert property(reject_on (!a) " it should be “assert property(reject_on (a)”.
Could you please explain ?
Does below cod work ?
assert property (@(posedge clk) $rose(b) |-> (reject_on(a) c[1:$]);
[/code]
In reply to cool_cake20:
What I initially wrote was correct for the original requirements:
“Pulse A should not fall between these two pulses(B and C). It be either before B or after C.”
meaning (my interpretation) that if A==0, it should fail.
ap_abc: assert property(reject_on (!a) // reject if a==0, since !a==1, and abort condition is true
@(posedge b) 1’b1 |-> @(posedge c) 1’b1); / is correct.
For this requirement
“If in between B and C there may be any number of clock cycles like [1:$] in a given simulation but A should not be become high(meaning must be 0, if 1 → fail) in between B and C.” then
ap_abc: assert property(reject_on (a)
From the syntax of a property
property_expr ::= // includes
reject_on ( expression_or_dist ) property_expr
Thus,
assert property (@(posedge clk) rose(b) |-> (reject_on(a) ##[1:] c); // is correct
// The " c[1:]" is incorect, unless you mean c[*1:], which is a repeat operator
Thanks Ben for clarification ,
i went by subject of post “Assertion to check if A does not rise between pulse B and Pulse C”
