I have a signal ‘b’ which should be asserted before say 10 cycles OR after 10 cycles of another signal ‘a’ being asserted.
$rose(a) |-> ##[-10:10] $rose(b) //which is syntactically wrong
I tried implementing this way:
property rise_a;
$rose(a) |-> ##[0:10] (b);
endproperty: rise_a
property rise_b;
$rose(b) |-> ##[0:10] (a);
endproperty: rise_b
property combine_event; @(posedge clk)
rise_a or rise_b;
endproperty: combine_event
assert_event:
assert property(combine_event)
else `uvm_error("ASSERT", "error")
This takes account of rise of signal b too which I want to ignore.
Please suggest me a better way to do this.
In reply to PavanSP:
Consider the following with a lock variable to lockout the rose(a) or rose(b) if one was triggered.
bit clk, a, b, lock;
initial forever #10 clk=!clk;
function void setlock(bit x);
lock=x;
ap_a: assert property(@ (posedge clk)
($rose(a) && !lock, setlock(1)) |-> ##[0:10] (b) ##0 (1, setlock(0)))
else setlock(0); // releas lock if pass or fail
ap_b: assert property(@ (posedge clk)
($rose(b) && !lock, setlock(1)) |-> ##[0:10] (a) ##0 (1, setlock(0)))
else setlock(0);
- SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
- SVA: Package for dynamic and range delays and repeats | Verification Academy
- SVA in a UVM Class-based Environment
You may want to consider 2 sets of locks to handle boundary conditions
bit clk, a, b, locka, lockb;
function void setlocka(bit x);
locka=x;
function void setlockb(bit x);
lockb=x;
($rose(a) && !lockb, setlockb(1)) |-> ##[0:10] (b) ##0 (1, setlockb(0)))
else setlockb(0); // release lock if pass or fail
($rose(b) && !lock, setlocka(1)) |-> ##[0:10] (a) ##0 (1, setlocka(0)))
else setlocka(0);
I did not test this, but these are things you can consider and verify.
