Assertion on Sva
I want to write a assertion to check whether the variable b occurs after 50 clock cycles of last occurance of variable a .
Here variable a is Valid and is randomised n of times.
and variable b idles ideal.
so we need to write assertion to check if after last occurance of valid and count 50 edge of clk and then check ideal is high , so assertion passes.
it fails if ideal is low at 50 clockedge .
so hindrance is checking for last time the variable a which is valid is high as it can go high n of times.
In reply to bhj78:
Are you saying that for every occurrence of “a” then variable b occurs after 50 clock cycles?
Or, are you saying that if I have something like:
a[*3] ##1 !a then b after the last b?
Pehaps something like: $rose(a) ##1 !a[->1] |-> ##50 b;
Clarify your requirements
Ben@systemverilog.us
or Links_to_papers_books - Google Docs
Hi Ben ,
I mean to say
No, we are only concerned about the last occurrence of “a”.I mean after last occurrence of “a”
a[*3] ##1 !a then b after the last b? Not this
but something like
a[*3] ##1 !a then b after the last a? this but here a is getting repeated n number of times at any interval as it is randomised so
Pehaps something like: $rose(a) ##1 !a[->1] |-> ##50 b;// donot know this will catch the last occurance of a
In reply to bhj78:
Catches the last occurrence of a before another rose of a.
No assertion will predict another repeats of a.
You may need some support logic or other info to limit what you are searching for. Again, you have to define what “Last” means.
Ben
In reply to bhj78:
Hi Ben ,
I mean to say
but something like
  a will be asserted within 50 cycles. if a is not asserted within 50 cycles , then b should be asserted. Should we consider that a will be the last occurrence?
 always@(posedge clk) begin
   if(a) count <= 0 ;
   else  count <= count + 1 ;
 assert property(@ posedge clk    count >= 50 |-> b)
 is there case there in signal a can be asserted after 50 clock cycles?
In reply to kddholak:
yes there can be case where a can be asserted after 50 clock edge
In reply to bhj78:
How would design know its last a, and b should be asserted after 50 clock cycles ? here its not predictable behaviour.
if the design can predict the last a , and asserts b after 50 clock cycles. there should be some deterministic behavior
