In reply to Anudeep J:
It is best to express this in two assertions instead of one.
In general, multiple smaller assertions are preferred as they are easier to write and understand. Thus, usin “a” instead of your “out”
// a) a is asserted immediately if in=1.
// b) a is -de-asserted after n cycles if in=0;
let n=20;
int m=20;
ap_aON: assert property(@ (posedge clk) $rose(in) |-> a);
ap_aOFF_staticInfinite: assert property(@ (posedge clk) $fell(in) |=> !a[->1]); // n== infinity
ap_aOFF_staticN: assert property(@ (posedge clk) $fell(in) |=> ##n !a);
import sva_delay_repeat_range_pkg::*; // see the link to the package below
// the import statement should be below the module declaration
ap_aOFF: assert property(@ (posedge clk) $fell(in) |=> q_dynamic_delay(m) ##0 !a);
Just a note about your use of the words asserted and de-asserted. This usually implies a change of state from false to true and then a change from true to false, which is why we use**$rose/$fell**.
What you wrote reads “every cycle that in is true out must be true at the same time, and every cycle that in is false, out must be true at lease once between two and six cycles afterwards”
