Assertion for signal stability inside a window
Hi all,
my purpose is to check that ‘c’ is stable since a fell down (and b is low) and until a goes high again.
I wrote this SVA:
assert property (@(posedge clk) disable iff (!reset_n) (!a && !b |=> ($stable(c) throughout (a) [-> 1])))
I’ve uploaded the image here…
The problem is that the assertion fails because it’s checking the clock next a returns high
Can anyone help me with this?
In reply to alexkidd84:
Your requirements are not clear; I believe that this is what you are trying to express:
At (fell(a) && !b) then starting from the next clock “c” holds the value it had at the fell(a)
until a rose(a). At the rose(a), “c” can change value.
//my purpose is to check that 'c' is stable since a fell down (and b is low)
    //and until a goes high again.
    property p_cstable;
        bit v;
        ($fell(a) && !b, v=c )|=>  c==v s_until  $rose(a);
    ap_c_stable: assert property(p_cstable);
If this is not your requirements, then please re-express them again.
    Verification Horizons - March 2018 Issue | Verification Academy
  2. SVA: Package for dynamic and range delays and repeats | Verification Academy
// Ths is equivalent to the  property p_cstable
ap_c_stable2: assert property(@ (posedge clk) disable iff (!reset_n)
       ($fell(a) && !b)|=> $stable(c) s_until  $rose(a));
    property p_cstable;
        bit v;
Thanks Ben!!
I was using 2005 sv version and I didn’t know the construct s_until.
