In reply to UVM_LOVE:
The application if your test vectors because you are very much dependent on the sequence in which the simulator processes the code. You have:
always #5 clk = ~clk; //clock generation
//generating 'a'
a=1; b=1;
If a=1 is processed by the simulator BEFORE the (@(posedge clk) a |-> …
the sampled value of “a” is 1. HOWEVER,
If a=1 is processed by the simulator AFTER the (@(posedge clk) a |-> …
the sampled value of “a” is 0, the defaulted value in the declaration.
SVG has explicit timing regions to prevent this issue. See my answer at
https://verificationacademy.com/forums/systemverilog/understanding-systemverilog-scheduling-better
The key here is that your test vectors should be applied with a nonblocking assignment (i.e., the <= ). This is the template I use to check assertions. I modify the variables and constraints as needed.
module top;
`include "uvm_macros.svh"
import uvm_pkg::*;
bit clk, a, b, reset_n;
initial forever #10 clk = !clk;
$timeformat(-9, 0, " ns", 10);
$display("%t", $realtime);
always @(posedge clk) begin
property p;
int v;
@(posedge clk) disable iff (reset_n == 0) a |-> b;
bit v_a, v_b, v_err;
repeat (200) begin
@(posedge clk);
if (!randomize(
v_a, v_b, v_err
) with {
v_a dist {
1'b1 := 1,
1'b0 := 1
v_b dist {
1'b1 := 1,
1'b0 := 2
v_err dist {
1'b1 := 1,
1'b0 := 15
`uvm_error("MYERR", "This is a randomize error");
a <= v_a;
if (v_err == 0) b <= v_b;
else b <= !v_b;
$finish;
- Free books:
- Component Design by Example FREE BOOK: Component Design by Example … A Step-by-Step Process Using VHDL with UART as Vehicle | Verification Academy
- Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb
- A Pragmatic Approach to VMM Adoption
http://SystemVerilog.us/vf/VMM/VMM_pdf_release070506.zip
http://SystemVerilog.us/vf/VMM/VMM_code_release_071806.tar
- Papers:
Understanding the SVA Engine,
Verification Horizons - July 2020 | Verification Academy
Reflections on Users’ Experiences with SVA, part 1
Reflections on Users’ Experiences with SVA | Verification Horizons - March 2022 | Verification Academy
Reflections on Users’ Experiences with SVA, part 2
Reflections on Users’ Experiences with SVA, Part II | Verification Horizons - July 2022 | Verification Academy
Understanding and Using Immediate Assertions
Understanding and Using Immediate Assertions | Verification Horizons - December 2022 | Verification Academy
SUPPORT LOGIC AND THE ALWAYS PROPERTY
http://systemverilog.us/vf/support_logic_always.pdf
SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
SVA in a UVM Class-based Environment
SVA for statistical analysis of a weighted work-conserving prioritized round-robin arbiter.
https://verificationacademy.com/forums/coverage/sva-statistical-analysis-weighted-work-conserving-prioritized-round-robin-arbiter.
