Please check the above image for the requirement:
only 1 pass scenario exists since signal_2 is expected to be exactly same as signal_1 but a delayed version;
fail (there can be many other fail scenarios in the picture i just mentioned 1 such case).
In reply to gumpena@usc.edu:
Keep in mind that an assertion is a statement or directive that a given property is required to hold. Assertions can be expressed in many ways, including regular code.
In SystemVerilog, that can be done in SVA or other plain SystemVerilog options.
Your requirement to verify that a wave of any shape, the duration of highs and lows of s1 are the same as s2, but delayed.
It’s too complex to do in SVA, but you can use the task method, as explained in my paper
SVA Alternative for Complex Assertions https://verificationacademy.com/news/verification-horizons-march-2018-issue
Below is an untested method where I measure that the duration in cycles of s1 pulse in high level is the same as s2 (delayed) also staying a 1 for that duration.
You need to do the same for when the signals are in the low state, the t_fell() task.
task automatic t_rise();
int s1_r1r1; // S1 rise to rise
int s2_r1r1; // S2 rise to rise
s1_r1r1=0;
begin // record wave for s1
while (s1==1) begin
@(posedge clk)
s1_r1r1++; // compute #cycles s1==1
while (s2==1) @(posedge clk); // wait for s2 to rise
s2_r1r1=0;
while (s2==1) begin
@(posedge clk)
s2_r1r1++; // compute #cycles s1==1
join
label: assert (s1_r1r1==s2_r1r1)
else $error("s1 high pulse != s2 high pulse ");
always @(posedge clk) begin
if($rose(s1)) t_rise();
if($fell(s1)) t_fell();
Another approach is to first compute the initial delay between S1 and S2 and store that in a variable. Using the package sva_delay_repeat_range_pkg;
(item 2 in my signature).
// v is first computed. Assertions disabled
$rose(S1) |-> q_dynamic_delay(v) ##0 $rose(S2);
$fell(S1) |-> q_dynamic_delay(v) ##0 $fell(S2);
Thanks a ton for your prompt response, after going through the 2 solutions you mentioned above I came up with the below 2 scenarios (image attached: if not able to view here is the link Imgur: The magic of the Internet).
Though I have not tested the 2 approaches you mentioned. I suspect case 1 will return pseudo pass with approach 1 and case 2 is interesting to try with approach 2. However thanks a lot i can build upon the idea you gave and give this a try.
@(posedge clk);
while (!rose(S1) || !$fell(S1)) begin
assert(!rose(S2) || !$fell(S2))
else $error("S1 pulse wih no s2 pulse ");
@(posedge clk);
You can get a partial check through some modeling code:
bit s1_seen;
always_ff @(posedge clk) begin : glue_logic
if ($rose(sig_1) begin
s1_seen <= 1'b1;
if ($rose(sig_2) begin
s1_seen <= 1'b0;
end : glue_logic
// Now a property..
$rose(sig_2) |-> s1_seen;
I term this as weak as it does not take care of all scenarios, but towards that direction.
