Assert number of times an event occurs
hi,
what is the proper way to assert number of times a signal(s1) changes (either rise or fall) in a time interval (end indicated by rise of signal s2);in a formal environment.
In reply to Veeresh_vs:
What are the requirements? Sig “a” shall change values “n” times between sig “b” and sig “c”.
Is “n” a constant or the value of a variable?
Once the requirements are defined, you can write an assertion in SVA or SV, see my verification Horizons paper (in latest issue)
Hint : use local variable as counter.
Ben systemverilog.us
Here is a potential solution, assuming “n” is a constant at elaboration time.
  timeunit 1ns;     timeprecision 100ps;
    bit clk, a, b, c;
    let n=4;
    initial forever #10 clk=!clk;
    //  Sig "a" shall change values "n" times between sig "b" and sig "c".
    ap_abc: assert property( $rose(b) |-> $changed(a)[=n] intersect c [->1]);
    // Sig "a" shall ==1 values "n" times between sig "b" and sig "c".
    ap_abc2: assert property( $rose(b) |-> a[=n] intersect c [->1]);
      repeat(200) begin
        @(posedge clk);
        if (!randomize(a, b, c)  with
        { a dist {1'b1:=1, 1'b0:=2};
         b dist {1'b1:=1, 1'b0:=6};
         c dist {1'b1:=1, 1'b0:=10};
    $stop;
See Paper: VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
hi Ben, thanks for the reply.
to clarify… currently i’am assuming ‘n’ to be constant value assigned to a register ;this need to be sampled and assert that s1 has to rise n times within event s2.
OK, here is quite a dump of options; you’ll need to analyze those and explore what is correct for you. At the bottom is the total code with a testbench. Below are specific snippets with comments.
// This assertion seems to meet your requirements with the exception that I am using sig c
// instead of an event e
   property abc;
      int v;
      ($rose(b), v=n) |-> first_match(
      (($changed(a)[=1], v=v-1'b1, $display("%t v_thrd1= %d", $time, v) )[*0:$]  ##1 v<=0))
      intersect c [->1];
    ap_abc: assert property(abc);
// The event cause complications because with the ANDing of the 2 threads,
// there is a separate local variable for each thread
    property abe; // DOES NOT WORK, DO NOT USE
      int v;
      (($changed(a)[=1], v=v-1'b1, $display("%t v_thrd1= %d",$time, v) )[*0:$]  ##1 v<=0))
      // intersect c [->1];
      and @e (1, $display("%t v_thrd2= %d", $time, v)) ##0 v<=0;
      //  NOT THE SAME V, BUT A DIFFERENT COPY
// You could create a signal d out of the event e, and use something
// like the top assertion
 always @e begin
      d<=1'b1;
      @(posedge clk) d <= 1'b0;
  property abe_d;
      int v;
      intersect d [->1];
    ap_abe_d: assert property(abe_d);
// Another possibility is to use tasks, as explained in my paper
// https://verificationacademy.com/forums/systemverilog/vf-horizonspaper-sva-alternative-complex-assertions
// Formal tools don't handle this approach.
   task automatic t_abe();
      automatic int v;
        fork1: begin //: th1
          if($rose(b)) v=n;
          else  disable t_abe; //disable fork1;
          forever begin : fv1
            if ($changed(a)) v=v-1'b1;
            @(posedge clk);
          end : fv1
        end //: th1
        fork2: begin //: th2
          if(!$rose(b))  disable t_abe; // disable fork2;
          @e assert(v==0);
          $display("%t v_task= %d", $time, v);
          if(v==0) -> ep; else -> ef;
          disable t_abe;
          //disable fork1;
          //disable fork2; // return is illegal here
        end //: th2
      join
    always @(posedge clk)  begin
      t_abe();
 // the testbench
  bit clk, a, b, c, d;
  event e, ep, ef;
  int n=3;
    // to clarify.. currently i'am assuming 'n' to be constant value assigned to a register;
    //this need to be sampled and assert that s1 has to rise n times within event s2.
    // //  Sig "a" shall change values "n" times between sig "b" and sig "c".
    property abc;
      int v;
      intersect c [->1];
    property abe_d;
      int v;
      intersect d [->1];
      int v;
    ap_abe: assert property(abe);
    always_ff @(posedge clk) begin
      if(c) ->e;
    always @e begin
      d<=1'b1;
      automatic int v;
          if($rose(b)) v=n;
          forever begin : fv1
            @(posedge clk);
          end : fv1
        end //: th1
          @e assert(v==0);
          disable t_abe;
          //disable fork1;
        end //: th2
      join
      t_abe();
    /* property testv;
    int v;
    @(posedge clk) (1, v=7) |=> ##1 (1, $display("v_thrd1= %d", v)) or
    (1, $display("v_thrd2= %d", v)) ##2 1;
  ap_testv: assert property(testv);
  ap_abc2: assert property( $rose(b) |-> a[=n] intersect c [->1]); */
    repeat(10000) begin
      @(posedge clk);
      c dist {1'b1:=1, 1'b0:=9};
  $stop;
Not sure if disable of task name disables all running tasks by that name, rather than the individual one. Of so, use
// disable t_abe; // mo
disable fork1;
disable fork2;
Ben Ben@systemverilog.us
Since you mentioned formal - your best bet is to write an always block and implement that counter.
Then use an assertion around that counter
Regards
Srini
