Alternative via "throughout" and "s_until_with"
Specification ::
  • When request is asserted that grant is asserted the very next clock .
    grant must have been de-asserted prior to it’s assertion
  • grant must remain asserted as long as request is asserted
  • grant must de-assert the very next clock after request is de-asserted
  //   SOLUTION ::
  property  req_gnt ;
   @( posedge  clk )   $rose( req ) |->  ##1  $rose( grant ) ##0 grant[*1:$] ##0 $fell( req ) ##1 $fell( grant )  ;
I then tried a few alternatives ::
  //   ALTERNATIVE1  ::
  sequence  seq_req_grant ;
   $rose( req )  ##1 $rose( grant ) ;  //   Implication  can't  be  Used  in  Sequence  ,  hence  ##1  !!
  endsequence
  property  req_assert ;
     grant  s_until_with  $fell( req )  ;   //   ' grant '  remains  Asserted  till  ' req '   Goes  Low  !!
  property  req_assert_grant ;
     seq_req_assert |=>  $fell( grant )  ;    //  ERROR  with  antecedent  !!
  property  req_gnt ;
   @( posedge  clk )   req_grant  |->  req_assert_grant ;
 //   ALTERNATIVE2  ::
   sequence  req_grant ;
  endsequence
     grant  throughout  ##[1:$] $fell( req )  ;
  property  req_gnt ;
I believe using a property as antecedent of Implication Operator is Illegal .
Have a few questions ::
  1. Any suggestions for ALT1 and ALT2 ?
  2. For incomplete assertion , “s_until_with” throws a Failure at End of Simulation
    This seems like a better solution but does it have any implications ?
In reply to MICRO_91:
I like the way you clearly expressed the requirements. However, I am critical of the way you try to resolve each piece in a collective way by combining them in complex properties.
In general, it is best to write smaller assertions than larger more complex ones. Thius is my solution.
// 1) When request is asserted that grant is asserted the very next clock .
//    grant must have been de-asserted prior to it's assertion
    $rose( req ) |->  ##1 $rose( grant);
// 2) grant must remain asserted as long as request is asserted
    $rose( grant) |-> grant && req[*0:$] ##1 !req;
   // Same as
    $rose( grant) |-> grant && req s_until ##1 !req;
// 3) grant must de-assert the very next clock after request is de-asserted
   $fell(req) |->  ##1 $fell(grant);
I committed the strong in the qualification of the consequent. If this is of importance, then add the strong; for example:
rose( grant) |-> strong(grant && req[*0:] ##1 !req);
/If the strong or weak operator is omitted, then the evaluation of the sequence_expr (interpreted as a property) depends on the assertion statement in which it is used. If the assertion statement is assert property or assume property, then the sequence_expr is evaluated as weak(sequence_expr). Otherwise, the sequence_expr is evaluated as strong(sequence_expr)./
You are correct. However, the implies has a similar connotation to the |-> but with differences.
The implies has the form: property_expr1 implies property_expr2
It evaluates to true if either property_expr1 evaluates to false or property_expr2 evaluates to true. With the exception of vacuity, it is equivalent to : (not property_expr1) or (property_expr2). Thus, with the implies property operator, both sides of the operator are properties start at the same evaluation time and may end at different cycles.
Also, An evaluation attempt of a property of the form property_expr1 implies property_expr2 is nonvacuous if, and only if, the underlying evaluation attempt of property_expr1 is true and nonvacuous, and the underlying evaluation attempt of property_expr2 is nonvacuous.
  3. Papers:
is
same as
$rose( grant) |-> (grant && req)[*0:$] ##1 !req;
In reply to Jeff_Li_90:
Yes because the & & is an expression operator.
The expression grant && req is first evaluated before the sequential repeat operator.
However, the following is differen because of the ‘and’ sequential operator.
grant and req[*0:] ##1 !req; // same as (grant) and (req[*0:] ##1 !req) ;
For the property to be true, both concurrent sequences starting at the same cycle must be true.
