Hi all,
I’m using the latest 2016 VCS version and see an issue where disable iff cannot be used in an assertion property.
property valid_check;
@(posedge clk)
disable iff (!rst_n) (re[i] |=> valid[i-1]);
I see this error:
Lint-[SVA-DIU] Disable iff used
Disable iff is used in assertion 'genblk10Û0îunnamed$$_0: assert
property(@(posedge clk) disable iff ((!rst_n)
Is there an alternative for disable_iff?
user49
October 19, 2016, 11:51pm
2
In reply to tejaswig :
This forum does not discuss tools. However, looking at 1800, your code is correct.
property_declaration ::=
property property_identifier [ ( [ property_port_list ] ) ] ;
{ assertion_variable_declaration }
property_statement_spec
endproperty [ : property_identifier ]
property_statement_spec ::=
[ clocking_event ]
[ disable iff ( expression_or_dist ) ]
property_statement
Thus, the following code looks OK:
bit clk, rst_n=1;
logic[15:0] i, valid, re;
initial forever #10 clk=!clk;
@(posedge clk)
ap: assert property(valid_check);
I suggest that you contact your tool vendor support.
SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 0-9705394-2-8
Component Design by Example ", 2001 ISBN 0-9705394-0-1
VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
In reply to ben@SystemVerilog.us :
thanks for your response!
user60
October 30, 2016, 5:57am
4
That looks like a Lint message, look for it in your VCS doc. Maybe there is a reason why they discourage it? Perhaps because disable iff can’t be nested and hence could better be used with assert than property. I would also recommend to use “default disable iff”.
Regards
Srini
www.verifworks.com
