How to write and read into specific fields in a address mapped register?
I have a register named spu_rst_ctl_register with 2 fields
- spu_reset_enable_bit (1 bit wide )
- spu_reset_type_and_spu_reset_polarity_bit ( 2 bits wide)
- RFU (reserved for future use)
below is my register sequence code for write and read through frontdoor access. But using .write() method (which uses the hierarchy {.<register_instance>.write()}) applies to all fields.
So how to write and read from specific field at a given point of time?
class spu_rst_ctl_reg extends uvm_reg;
`uvm_object_utils(spu_rst_ctl_reg)
rand uvm_reg_field spu_reset_enable_bit;
rand uvm_reg_field spu_reset_type_bit_spu_reset_polarity_bit;
// rand uvm_reg_field spu_reset_duration;
function new (string name = "spu_rst_ctl_reg");
super.new(name,32,UVM_NO_COVERAGE);
function void build();
spu_reset_enable_bit = uvm_reg_field :: type_id :: create ("spu_reset_enable_bit");
spu_reset_enable_bit.configure(.parent(this),
.size(1),
.lsb_pos(0),
.access("RW"),
.volatile(0),
.reset(32'hF),
.has_reset(1),
.is_rand(1),
.individually_accessible(1)
spu_reset_type_bit_spu_reset_polarity_bit = uvm_reg_field :: type_id :: create ("spu_reset_type_bit_spu_reset_polarity_bit");
spu_reset_type_bit_spu_reset_polarity_bit.configure(.parent(this),
.size(2),
.lsb_pos(1),
.access("RW"),
.volatile(0),
.reset(32'hF),
.has_reset(1),
.is_rand(1),
// spu_reset_duration = uvm_reg_field :: type_id :: create ("spu_reset_duration");
// spu_reset_duration.configure(.parent(this),
// .size(15),
// .lsb_pos(3),
// .access("RW"),
// .volatile(0),
// .reset(32'hF),
// .has_reset(1),
// .is_rand(1),
// .individually_accessible(1)
spu_clk_en = spu_clock_enable :: type_id :: create ("spu_clk_en");
spu_clk_en.configure(.parent(this),.size(1),.lsb_pos(3),.access("RW"),.volatile(0),.reset(1'b1),.has_reset(1),.is_rand(1),.individually_accessible(1));
spu_clk_gat = spu_clock_gat :: type_id :: create ("spu_clk_gat");
spu_clk_gat.configure(.parent(this),.size(3),.lsb_pos(4),.access("RW"),.volatile(0),.reset(1'b1),.has_reset(1),.is_rand(1),.individually_accessible(1)); */
