4 phase req ack
I am trying to drive ack from the test-bench, where req is input to the testbench
I have the following code ;-
task main();
  reg req_accepted=0;
 reg req_deasserted=0;
 forever begin
            thread1 capturing req;
        @(clocking_cb) ;
                if(req && !req_accepted) begin
                    $display("\n=== 1 req_accepted=%d  req_deasserted=%d at time =  %t ===",req_accepted,req_deasserted, $time)  ;
                    req_accepted <= 1 ;
                    $display("\n===  req=%d at time =  %t ===",read_trans[index].req, $time)  ;
                    ack <= 1 ;
                else if(req && req_accepted) begin
                    $display("\n=== 2 req_accepted=%d  req_deasserted=%d at time =  %t ===",req_accepted,req_deasserted, $time)  ;
                   $display("\n= req=%dat time =  %t ===",read_trans[index].req, $time)  ;
                    ack <= 1 ;
                else if(!(req) && req_accepted) begin
                    $display("\n=== 3 req_accepted=%d  req_deasserted=%d at time =  %t ===",req_accepted,req_deasserted, $time)  ;
                    req_deasserted <= 1 ;
                    req_accepted <= 0;
                    ack <= 1 ;
                else if(req_deasserted) begin
                    $display("\n=== 4 req_accepted=%d  req_deasserted=%d at time =  %t ===",req_accepted,req_deasserted, $time)  ;
                   $display("\n===  req=%dat time =  %t ===",read_trans[index].req, $time)  ;
                    ack <= 0 ;
                    req_deasserted <= 0;
                else begin
                    $display("\n=== 5 req_accepted=%d  req_deasserted=%d at time =  %t ===",req_accepted,req_deasserted, $time)  ;
                    ack <= 0 ;
                    req_accepted <= 0 ;
                    req_deasserted <= 0 ;
            thread 3, incremeting a variable
    join_any
for some time instances ack is rising at the same time as req,
but for most time instances it works
can anyone help me in debugging this ?
Just comments rather than a solution to your issues:
  1. If main is not in a class, then make the task automatic
    task automatic main();
  2. Insure that the signal *req * is assigned nonblocking. I presume you did that already.
    Also
  3. should this
    be
    else if(!(req) && !req_accepted) begin
thanks for your reply
  1. it’s inside a class actually,
  2. req is coming from the RTL can’t control that.
It has something to do with the thread issue mostly, may be multiple threads are trying to drive ack rather than just one, is there any other solution to this rather than automatic
class four_phase_handshake;
semaphore ack_semaphore;
reg req_accepted = 0;
reg req_deasserted = 0;
reg ack = 0;
logic clocking_cb; // Input for the clock signal
logic req; // Input for the request signal
// Constructor
function new();
    ack_semaphore = new(1); // Initialize semaphore with 1 token
task main();
    forever begin
                // Simulated thread for capturing req
                // This thread can be customized as needed
                @(posedge clocking_cb);
                $display("Thread 1: Capturing req at time %0t", $time);
                // Main handshake logic
                ack_semaphore.get(); // Acquire semaphore
                if (req && !req_accepted) begin
                    $display("\n=== 1 req_accepted=%d  req_deasserted=%d at time = %t ===", req_accepted, req_deasserted, $time);
                    req_accepted <= 1;
                    ack <= 1;
                else if (req && req_accepted) begin
                    $display("\n=== 2 req_accepted=%d  req_deasserted=%d at time = %t ===", req_accepted, req_deasserted, $time);
                    ack <= 1;
                else if (!req && req_accepted) begin
                    $display("\n=== 3 req_accepted=%d  req_deasserted=%d at time = %t ===", req_accepted, req_deasserted, $time);
                    req_deasserted <= 1;
                    req_accepted <= 0;
                    ack <= 1;
                else if (req_deasserted) begin
                    $display("\n=== 4 req_accepted=%d  req_deasserted=%d at time = %t ===", req_accepted, req_deasserted, $time);
                    ack <= 0;
                else begin
                    $display("\n=== 5 req_accepted=%d  req_deasserted=%d at time = %t ===", req_accepted, req_deasserted, $time);
                    ack <= 0;
                    req_accepted <= 0;
                ack_semaphore.put(); // Release semaphore
                // Simulated thread for another task, such as incrementing a variable
                $display("Thread 3: Incrementing variable at time %0t", $time);
        join_any
tried using semahores
this also didn’t work
WHy do you have a “join_any”?
If this fork ends first, you don’t finish the other 2 fork elements.
Try “join” instead.
I can’t get rid of join_any(it has to stay), and just for trying I tried replacing it with join, but it again didn’t help
Without going thru the logic, you are coving 3 of the 4 possible cases. This case is not explicitly specified,
maybe it is by the
Take a look at your logic here.
also, can you show a waveform of the problem?
yes it’s actually the same thing,
problem req and ack getting asserted at the same time
after certain time stamp in the simulation.
I see ack <= 1; when
I see ack <= 0 when else if (req_deasserted)
Question: what happens in the 1st 3 cases if is (req_deasserted)
I don’t know your design or rquirements, but if you are designing a verification environment for the RTL, maybe something is wrong with your logic.
else if(req_deasserted) is simply same as else if(!req & !req_accepted)
you can even remove it from the code and just use the above, it will be same
You need to analyze the logic; maybe you have some sort of latchup situation or incorrect RTL. discuss it with a colleague. Do a step-by-step trace.
Best wishes
