[UVM_OBJ] when objections are used in env but results are displayed of test_case phase
I have developed this small tb.
/*transaction class */
`include "uvm_macros.svh";
class configuration extends uvm_sequence_item;
  `uvm_object_utils(configuration)
  bit [7:0] data_width;
  int unsigned no_of_trans;
  function new(string name = "configuration");
  function void set_cfg();
    if( ! $value$plusargs ("data_width=%d",data_width ))
      data_width = 32;
    if(!$value$plusargs ("no_of_trans=%d",no_of_trans ))
       no_of_trans = 10;
class transaction extends uvm_sequence_item;
  `uvm_object_utils(transaction)
  bit [3:0] data;
  function new(string name = "transaction");
interface data_if(input clk);
  bit [5:0] data;
endinterface
/* sequence class*/
class my_sequence extends uvm_sequence#(transaction);
  `uvm_object_utils(my_sequence)
  transaction req;
  int LIMIT;
  task body();
    for (int i = 0; i < LIMIT; i++) begin
    req= new("req");
         req.data = 1;
    start_item(req);
   //    req.data = 1;
    //  #60;
  //  req.randomize();
    finish_item(req);
/* sequencer*/
class sequencer extends uvm_sequencer#(transaction);
  `uvm_component_utils(sequencer)
  //constructor
    super.new(name,parent);
/* driver class*/
class driver extends uvm_driver#(transaction);
  // Virtual Interface
  virtual data_if vif;
   transaction req;
  `uvm_component_utils(driver)
  // Constructor
  endfunction : new
    if(!uvm_config_db#(virtual data_if)::get(this, "", "vif", vif))
       `uvm_fatal("NO_VIF",{"virtual interface must be set for: ",get_full_name(),".vif"});
    req = new("req");
  endfunction: build_phase
  // run phase
    drive();
    seq_item_port.item_done();
  endtask : run_phase
  // drive
  virtual task drive();
   // req.print();
    $display("%0t:req.data=%d",$time, req.data);
   @(posedge vif.clk);
   vif.data<= req.data;
  endtask : drive
endclass : driver
/*agent class*/
class agent extends uvm_agent;
  driver    drv;
  sequencer seqr;
  // UVM automation macros for general components
  `uvm_component_utils(agent)
  // constructor
  endfunction : new
  // build_phase
    drv= driver::type_id::create("drv", this);
    seqr = sequencer::type_id::create("seqr", this);
  endfunction : build_phase
    drv.seq_item_port.connect(seqr.seq_item_export);
  //  m_drv0.seq_item_port.connect (m_seqr0.seq_item_export);
endclass : agent
/*env class*/
class my_env extends uvm_env;
  `uvm_component_utils(my_env)
  agent agt;
  endfunction : new
    agt= agent::type_id::create("agt",this);
    phase.raise_objection(this);
     $display("%0t",$time);
     #10;
    phase.drop_objection(this);
  `uvm_component_utils(my_test)
  my_sequence seq;
  my_env env;
  configuration cfg;
  endfunction : new
    env = my_env::type_id::create("env", this);
    seq = my_sequence::type_id::create("seq");
    cfg = configuration ::type_id :: create("cfg");
    cfg.set_cfg();
    seq.LIMIT=10;
    seq.start(env.agt.seqr);
module tb_top;
  bit clk;
  //clock generation
  always #5 clk = ~clk;
  //creatinng instance of interface, inorder to connect DUT and testcase
  data_if intf(clk);
  //enabling the wave dump
    uvm_config_db#(virtual data_if)::set(uvm_root::get(),"*","vif",intf);
    $dumpfile("dump.vcd"); $dumpvars;
    run_test("my_test");
Output:
# UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(277) @ 0: reporter [Questa UVM] QUESTA_UVM-1.2.3
# UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(278) @ 0: reporter [Questa UVM]  questa_uvm::init(+struct)
# UVM_INFO @ 0: reporter [RNTST] Running test my_test...
# 0
# 0:req.data= 1
# UVM_INFO verilog_src/uvm-1.1d/src/base/uvm_objection.svh(1267) @ 10: reporter [TEST_DONE] 'run' phase is ready to proceed to the 'extract' phase
# --- UVM Report Summary ---
# ** Report counts by severity
# UVM_INFO :    4
# UVM_WARNING :    0
# UVM_ERROR :    0
# UVM_FATAL :    0
# ** Report counts by id
# [Questa UVM]     2
# [RNTST]     1
# [TEST_DONE]     1
# ** Note: $finish    : /usr/share/questa/questasim/linux_x86_64/../verilog_src/uvm-1.1d/src/base/uvm_root.svh(430)
#    Time: 10 ns  Iteration: 55  Instance: /tb_top
Here, objection is raise inside run_phase of env and in main_phase of test, their is no objection, still as per output objection in run_phase, let main_phase of test executes and once that objection is dropped , simulation ends. Isn’t it wrong? how can objection of env can control test 's phase?
In reply to juhi_p:
The simulator is explicitly doing what you were implementing. You have the objections in the run_phase of the env. It will be raised at runtime zero. Then it waits #1ß and drops the objection resulting in stopping the simulation (proceeding to extract_phase).
A few remarks with respect to your code:
(1) Using the env run_phase with your content is a bad choice for implementing the objections. Recommended is to implement the objections in the run_phase of the test.
(2) Mixing run_phase and main_phase in a UVM environment is a bad coding style and could result in serious problems.
(3) Transient objects are never constructed in the build_phase of a component. They have to be constructed in the run_phase.
(4) Connecting the virtual interface should be done in the connect_phase and not in the build_phase. This could also result in problems.
As per your remark , I changed code as below:
  agent agt;
  endfunction : new
     #100;
  my_sequence seq;
  my_env env;
  configuration cfg;
  endfunction : new
    cfg.set_cfg();
    seq.LIMIT=10;
output:-
# 0
# 0:req.data= 1
# 5:req.data= 1
# 15:req.data= 1
# 25:req.data= 1
# 35:req.data= 1
# 45:req.data= 1
# 55:req.data= 1
# 65:req.data= 1
# 75:req.data= 1
# 85:req.data= 1
# UVM_INFO verilog_src/uvm-1.1d/src/base/uvm_objection.svh(1267) @ 100: reporter [TEST_DONE] 'run' phase is ready to proceed to the 'extract' phase
# UVM_INFO :    4
# UVM_WARNING :    0
# UVM_ERROR :    0
# UVM_FATAL :    0
Even in this case run_phase of test gets execute fully, Is it due to count of objection raise inside env also propagates to test and cause this to happen ?
In reply to juhi_p:
The objection is not propagating at all. You can implement objections in different components/objects. The simulator is checking the status of all objections. If all have been dropped it stops the simulation.
You have only 1 objection mechanism. It raises an objection at runtime 0 and it drops the objection at runtime 100. Then the simulation stops. This what you see in your logfile.
BTW you did not follow my recommendations.
