[UVM_OBJ] when objections are used in env but results are displayed of test_case phase
As per your remark , I changed code as below:
class my_env extends uvm_env;
  `uvm_component_utils(my_env)
  agent agt;
  function new (string name, uvm_component parent);
    super.new(name, parent);
  endfunction : new
    agt= agent::type_id::create("agt",this);
    phase.raise_objection(this);
     $display("%0t",$time);
     #100;
    phase.drop_objection(this);
class my_test extends uvm_test;
  `uvm_component_utils(my_test)
  my_sequence seq;
  my_env env;
  configuration cfg;
  endfunction : new
    env = my_env::type_id::create("env", this);
    seq = my_sequence::type_id::create("seq");
    cfg = configuration ::type_id :: create("cfg");
    cfg.set_cfg();
    seq.LIMIT=10;
    seq.start(env.agt.seqr);
output:-
# UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(277) @ 0: reporter [Questa UVM] QUESTA_UVM-1.2.3
# UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(278) @ 0: reporter [Questa UVM]  questa_uvm::init(+struct)
# UVM_INFO @ 0: reporter [RNTST] Running test my_test...
# 0
# 0:req.data= 1
# 5:req.data= 1
# 15:req.data= 1
# 25:req.data= 1
# 35:req.data= 1
# 45:req.data= 1
# 55:req.data= 1
# 65:req.data= 1
# 75:req.data= 1
# 85:req.data= 1
# UVM_INFO verilog_src/uvm-1.1d/src/base/uvm_objection.svh(1267) @ 100: reporter [TEST_DONE] 'run' phase is ready to proceed to the 'extract' phase
# --- UVM Report Summary ---
# ** Report counts by severity
# UVM_INFO :    4
# UVM_WARNING :    0
# UVM_ERROR :    0
# UVM_FATAL :    0
Even in this case run_phase of test gets execute fully, Is it due to count of objection raise inside env also propagates to test and cause this to happen ?
