Hi everyone,
I saw some codes given below. They call $sdf_annotate(xxx.sdf, inst_name.DUV). I could not understand why. SDF is a file including timing informations and delay. Why would we need to call a sdf file for verification?
In the initial stages of your design you will be performing “functional” simulations to ensure the logic in your circuit operates correctly. After your FPGA or ASIC tools generate a layout for your gate-level design, you may want to perform a final simulation with back-annotated timing information generated during the layout process to account for real world interconnect and gate delays. This “timing” simulation is often used as a final check to ensure that unexpected delays generated during the layout process don’t create timing violations in your design. The layout tools will create a Standard Delay File (SDF) that includes this timing information
`ifdef TIMING_SIM
$sdf_annotate(a_project//design/netlist/xx_top.sdf", AL_0.DUV)
`endif
