I have an RTL module …
module foo;
// RTL code
// Then there is some SV code to introduce errors
`ifndef SYNTHESIS
error_module em_i0 ();
always @ (posedge some_event) begin
force something;
release something;
`endif
How do I remove the SV code in this module and do the same thing using UVM bind?
Thank You!
If the something is a wire, you can do
module to_bind_in_another_module(output wire something, input some_event);
force something=1;
release something;
bind foo to_bind_in_another module bind_inst0(somesignalinfoo,anothersignalinfoo);
But this will not work if the signal is a variable.
My bad!
It isn’t a wire; it is of type reg.
reg [width-1:0] something;
Please advise. Thank You!
In reply to new_to_uvm:
This might work using an upward name hierarchical reference.
module to_bind_in_module_foo;
always @ (posedge foo.some_event) begin
force foo.something=1;
release foo.something;
bind foo to_bind_in_module_foo bind_inst0();
For reg[width-1:0] something,
I think ref port can be used.
module to_bind_in_another_module(ref reg[width-1:0] something, input some_event);
force something=1;
release something;
