I want to add delay. For example,
#5ns;
force tb.a = 1’b1;
And I get an error:
UVM_FATAL |@ 15000 ps | RUNPHSTIME The run phase must start at time 0, current time is 15000 ps. No non-zero delays are allowed before run_test(), and pre-run user defined phases may not consume simulation time before the start of the run phase.
How to fix it ?
Alex
In reply to alexd555:
You cannot get that error message unless you call run_test(). That should be in another initial block.
If not in run_test then where ? Only in testbench ?
It looks like you do not have a UVM testbench.
Could you show some code, please?
what is the need of run_test getting started at 0 time only?
if I write,
#10ns;
run_test(“base_test”)
it gives an error which is mentioned above.
In reply to Dhanesh_Padia:
It’s a methodology guideline that has been hard coded into the code. There is no technical reason.
