In reply to dhserfer:
Hey, I’m adding my sequences, driver and test designs here:
Sequences:
package cpu2reg_sequences;
import uvm_pkg::*;
class cpu2reg_transaction extends uvm_sequence_item;
`uvm_object_utils(cpu2reg_transaction)
rand bit [1:0] A;
rand bit WE;
rand int WD;
// add constraints
function new (string name = "");
super.new(name);
endfunction: new
function string convert2string;
return $psprintf("A:\t%0b\n CPU_WE:\t%0b\n Write_Address:\t%0h", A, WE, WD);
endfunction: convert2string
// do copy, do compare
endclass: cpu2reg_transaction
class cpu2reg_rw extends uvm_sequence #(cpu2reg_transaction);
`uvm_object_utils(cpu2reg_rw)
super.new(name);
endfunction: new
task body;
cpu2reg_transaction tx;
bit [1:0] a;
int d;
tx = cpu2reg_transaction::type_id::create("tx");
start_item(tx);
assert( tx.randomize() );
tx.WE = 0; // force the WE to Read
finish_item(tx);
a = tx.A;
d = tx.WD;
++d; // modify the data
start_item(tx);
assert( tx.randomize() with { tx.A == a; tx.WE == 1; tx.WD == d; } );
finish_item(tx);
endtask: body
endclass: cpu2reg_rw
class seq_of_commands extends uvm_sequence #(cpu2reg_transaction);
`uvm_object_utils(seq_of_commands)
`uvm_declare_p_sequencer(uvm_sequencer#(cpu2reg_rw))
rand int n; // nob on UVM
constraint how_many { n inside {[2:4]}; }
super.new(name);
endfunction: new
task body;
repeat(n)
cpu2reg_rw seq;
seq = cpu2reg_rw::type_id::create("seq");
assert( seq.randomize() );
seq.start(p_sequencer);
endtask: body
endclass: seq_of_commands
endpackage: cpu2reg_sequences
Driver:
class cpu2reg_driver extends uvm_driver #(cpu2reg_transaction);
`uvm_component_utils(cpu2reg_driver)
cpu2reg_config cpu2reg_config_0;
virtual cpu2reg_if cpu2reg_vi;
super.new(name, parent);
endfunction: new
assert( uvm_config_db #( cpu2reg_config )::get(this, "", "cpu2reg_config", cpu2reg_config_0) );
cpu2reg_vi = cpu2reg_config_0.cpu2reg_vi;
endfunction: build_phase
forever
@(posedge cpu2reg_vi.Clk);
seq_item_port.get(tx);
// Wiggle pins of DUT
cpu2reg_vi.A = tx.A;
cpu2reg_vi.WE = tx.WE;
cpu2reg_vi.WD = tx.WD;
//seq_item_port.item_done();
endtask: run_phase
endclass: cpu2reg_driver
Test:
class cpu2ocp_test extends uvm_test;
`uvm_component_utils(cpu2ocp_test)
cpu2reg_env cpu2reg_env_h;
endfunction: new
cpu2reg_config_0 = new();
if(!uvm_config_db #(virtual cpu2reg_if)::get( this, "", "cpu2reg_vi", cpu2reg_config_0.cpu2reg_vi))
`uvm_fatal("NOVIF", "No virtual interface set")
uvm_config_db #(cpu2reg_config)::set(this, "*", "cpu2reg_config", cpu2reg_config_0);
cpu2reg_env_h = cpu2reg_env::type_id::create("cpu2reg_env_h", this );
endclass: cpu2ocp_test
class test1 extends cpu2ocp_test;
`uvm_component_utils(test1)
endfunction: new
cpu2reg_rw seq;
phase.raise_objection(this);
seq.start(cpu2reg_env_h.cpu2reg_agent_h.cpu2reg_sequencer_h);
phase.drop_objection(this);
endtask: run_phase
endclass: test1
class test2 extends cpu2ocp_test;
`uvm_component_utils(test2)
endfunction: new
seq_of_commands seq;
seq = seq_of_commands::type_id::create("seq");
seq.start( cpu2reg_env_h.cpu2reg_agent_h.cpu2reg_sequencer_h );
endtask: run_phase
endclass: test2
class test3 extends cpu2ocp_test;
`uvm_component_utils(test3)
endfunction: new
seq.how_many.constraint_mode(0);
assert( seq.randomize() with {seq.n > 10 && seq.n < 20;});
endtask: run_phase
endclass: test3
I’ve modified my test block, so I’ve posted the updated one. Can you please tell me where I am going wrong in this.
Thank You.
