Zero simulation time
In reply to Ramakrishna Melgiri:
If you face an issue with time not progressing this is in most cases caused by the driver.
Firstly you should check if your driver sees the posdege of the clock.
Secondly if you are performing a get_next_item/get in the driver this requires an indication to the sequencer by issuing a item_done/put.
