Hi Team.
I have created a wrapper around my sv model. Some of the inputs and all the outputs to the wrapper and model is the same. But some of the inputs to the model are created in the wrapper, and the data type of this input is enumerated type.
typedef struct {
real amplitude;
real frequency;
real phase;
} signal_rf;
module rxbb_lp_model_wrapper
import analog_pack_sv::*;
import analog_model_ctrx_pack_sv::*;
import ams_signal_pack_sv::*;
VDD1V8BB ,
VSS1V8A ,
VSS1V8BB ,
VSS_SUB ,
bbmux_lp_n_ai_amplitude ,
bbmux_lp_n_ai_frequency ,
bbmux_lp_n_ai_phase ,
bbmux_lp_p_ai_amplitude ,
bbmux_lp_p_ai_frequency ,
bbmux_lp_p_ai_phase ,
lp_n_ai_amplitude ,
lp_n_ai_frequency ,
lp_n_ai_phase ,
lp_p_ai_amplitude ,
lp_p_ai_frequency ,
lp_p_ai_phase ,
ibg_lp_untrim_50u_p_ai ,
iptat_lp_untrim_50u_p_ai ,
lp_en_i ,
lp_noise_filter_en_i ,
lp_test_sel_i ,
trim_lp_fb_fc_i ,
trim_lp_pass_fc_i ,
vcm1_750m_ai ,
vcm3_600m_ai ,
lp1_n_amux_ao,
lp1_p_amux_ao,
lp2_n_amux_ao,
lp2_p_amux_ao,
lp_n_ao,
lp_p_ao
input analog_t VDD1V8BB;
input analog_t VSS1V8A;
input analog_t VSS1V8BB;
input analog_t VSS_SUB;
input analog_t bbmux_lp_n_ai_amplitude ;
input analog_t bbmux_lp_n_ai_frequency ;
input analog_t bbmux_lp_n_ai_phase ;
input analog_t bbmux_lp_p_ai_amplitude ;
input analog_t bbmux_lp_p_ai_frequency ;
input analog_t bbmux_lp_p_ai_phase ;
input analog_t lp_n_ai_amplitude ;
input analog_t lp_n_ai_frequency ;
input analog_t lp_n_ai_phase ;
input analog_t lp_p_ai_amplitude ;
input analog_t lp_p_ai_frequency ;
input analog_t lp_p_ai_phase ;
input analog_t ibg_lp_untrim_50u_p_ai [1:0];
input analog_t iptat_lp_untrim_50u_p_ai [1:0];
input logic lp_en_i;
input logic lp_noise_filter_en_i;
input logic lp_test_sel_i;
input logic [2:0] trim_lp_fb_fc_i;
input logic [3:0] trim_lp_pass_fc_i;
input analog_t vcm1_750m_ai;
input analog_t vcm3_600m_ai;
output analog_t lp1_n_amux_ao;
output analog_t lp1_p_amux_ao;
output analog_t lp2_n_amux_ao;
output analog_t lp2_p_amux_ao;
output analog_t lp_n_ao;
output analog_t lp_p_ao;
signal_rf bbmux_lp_p_ai;
signal_rf bbmux_lp_n_ai;
signal_rf lp_p_ai;
signal_rf lp_n_ai;
initial
bbmux_lp_n_ai.amplitude = bbmux_lp_n_ai_amplitude;
bbmux_lp_n_ai.frequency = bbmux_lp_n_ai_frequency;
bbmux_lp_n_ai.phase = bbmux_lp_n_ai_phase;
bbmux_lp_p_ai.amplitude = bbmux_lp_p_ai_amplitude;
bbmux_lp_p_ai.frequency = bbmux_lp_p_ai_frequency;
bbmux_lp_p_ai.phase = bbmux_lp_p_ai_phase;
lp_n_ai.amplitude = lp_n_ai_amplitude;
lp_n_ai.frequency = lp_n_ai_frequency;
lp_n_ai.phase = lp_n_ai_phase;
lp_p_ai.amplitude = lp_p_ai_amplitude;
lp_p_ai.frequency = lp_p_ai_frequency;
lp_p_ai.phase = lp_p_ai_phase;
// Instantiate the system_verilog model
rxbb_lp_model rxbb_lp_model_inst(
.VDD1V8BB(VDD1V8BB) ,
.VSS1V8A(VSS1V8A) ,
.VSS1V8BB(VSS1V8BB) ,
.VSS_SUB(VSS_SUB) ,
.bbmux_lp_n_ai(bbmux_lp_n_ai) ,
.bbmux_lp_p_ai(bbmux_lp_p_ai) ,
.ibg_lp_untrim_50u_p_ai(ibg_lp_untrim_50u_p_ai) ,
.iptat_lp_untrim_50u_p_ai(iptat_lp_untrim_50u_p_ai) ,
.lp_en_i(lp_en_i) ,
.lp_n_ai(lp_n_ai) ,
.lp_noise_filter_en_i(lp_noise_filter_en_i) ,
.lp_p_ai(lp_p_ai) ,
.lp_test_sel_i(lp_test_sel_i) ,
.trim_lp_fb_fc_i(trim_lp_fb_fc_i) ,
.trim_lp_pass_fc_i(trim_lp_pass_fc_i) ,
.vcm1_750m_ai(vcm1_750m_ai) ,
.vcm3_600m_ai(vcm3_600m_ai) ,
.lp1_n_amux_ao(lp1_n_amux_ao) ,
.lp1_p_amux_ao(lp1_p_amux_ao) ,
.lp2_n_amux_ao(lp2_n_amux_ao) ,
.lp2_p_amux_ao(lp2_p_amux_ao) ,
.lp_n_ao(lp_n_ao) ,
.lp_p_ao(lp_p_ao)
#(parameter time sample_rate=1ns) ( lp1_n_amux_ao, lp1_p_amux_ao, lp2_n_amux_ao, lp2_p_amux_ao,
lp_n_ao, lp_p_ao, VDD1V8BB, VSS1V8A, VSS1V8BB, VSS_SUB, bbmux_lp_n_ai, bbmux_lp_p_ai,
ibg_lp_untrim_50u_p_ai, iptat_lp_untrim_50u_p_ai, lp_en_i, lp_n_ai, lp_noise_filter_en_i,
lp_p_ai, lp_test_sel_i, trim_lp_fb_fc_i, trim_lp_pass_fc_i, vcm1_750m_ai, vcm3_600m_ai
timeunit 1ps;
timeprecision 1ps;
typedef struct {
real amplitude;
real frequency;
real phase;
} signal_rf;
input signal_rf bbmux_lp_p_ai;
input signal_rf bbmux_lp_n_ai;
input signal_rf lp_p_ai;
input signal_rf lp_n_ai;
This is the error I am getting
xmelab: *E,TYCMPAT (/var/vob/ctrx/ctrx44/vob/units/ctrx_tb_dig/source/sv/tb/abeam_wrapper_13/abeam_wrapper/rxbb_lp_model.sv,105|31): port or terminal connection type check failed on instance tb_rxbb_lp_model_wrapper.rxbb_lp_model_wrapper_inst (expecting datatype compatible with ‘unpacked structure rxbb_lp_model::signal_rf’ but found ‘unpacked structure $unit::signal_rf’ instead).
xmelab: *E,TYCMPAT (/var/vob/ctrx/ctrx44/vob/units/ctrx_tb_dig/source/sv/tb/abeam_wrapper_13/abeam_wrapper/rxbb_lp_model.sv,106|31): port or terminal connection type check failed on instance tb_rxbb_lp_model_wrapper.rxbb_lp_model_wrapper_inst (expecting datatype compatible with ‘unpacked structure rxbb_lp_model::signal_rf’ but found ‘unpacked structure $unit::signal_rf’ instead).
.lp_n_ai(lp_n_ai) ,
xmelab: *E,TYCMPAT (/var/vob/ctrx/ctrx44/vob/units/ctrx_tb_dig/source/sv/tb/abeam_wrapper_13/abeam_wrapper/rxbb_lp_model.sv,110|19): port or terminal connection type check failed on instance tb_rxbb_lp_model_wrapper.rxbb_lp_model_wrapper_inst (expecting datatype compatible with ‘unpacked structure rxbb_lp_model::signal_rf’ but found ‘unpacked structure $unit::signal_rf’ instead).
.lp_p_ai(lp_p_ai) ,
xmelab: *E,TYCMPAT (/var/vob/ctrx/ctrx44/vob/units/ctrx_tb_dig/source/sv/tb/abeam_wrapper_13/abeam_wrapper/rxbb_lp_model.sv,112|19): port or terminal connection type check failed on instance tb_rxbb_lp_model_wrapper.rxbb_lp_model_wrapper_inst (expecting datatype compatible with ‘unpacked structure rxbb_lp_model::signal_rf’ but found ‘unpacked structure $unit::signal_rf’ instead).
