As the statement says it all, I am looking for a concise way to write a constraint for setting variable number of LSB’s of a particular number (let’s say var) depending on another random variable(let’s say set_bits).
I thought to write as shown below, however, it says “Range width must be constant expression”
$countones(var[0 +: set_bits]) != 0;
In reply to rahulkumarbudhwani:
myVar < (1<<set_bits)
class Packet#(int size=5);
rand bit[size-1:0] number;
rand int unsigned setBits;
constraint SIZE{ setBits < size;}
constraint NUMBER{number == (1<<setBits);}
number=number-1;
function void display();
$display("LSB SetBits is %b",number);
module tb;
Packet#(10) pkt;
initial
pkt=new();
void'(pkt.randomize());
pkt.display();
