Writemem
Can the system task $writememh be executed within an object? Kindly let me know.
In my case, the code outline is as follows:
class environment_c;
bit [7:0] frame_out [1023:0];
bit [7:0] input[1023:0];
task process();
$readmemh("input.txt",input);
$writememh("out_frame.txt",frame_out); //Array is initialized prior to this
I have created an object, env_o and run this. $readmemh functions as expected but $writememh does not write any data into the file “out_frame.txt”, though it creates the file “out_frame.txt”.
Additionally, The following warning appears during simulation
**** Warning: ** Warning: (vsim-4014) No objects found matching ‘this’**.
In reply to Anuradha Rangineni:
task process();
$readmemh(“input.txt”,input);
$writememh(“out_frame.txt”,frame_out); //Array is initialized prior to this
This line of code:
will cause trouble, since you are using a Verilog reserved keyword (input) as a variable name.
Modified code to:
bit [7:0] frame_input[1023:0];
task process();
$readmemh(“input_frame.txt”,frame_input);
Modified the code to the above but still facing the error :
** Warning: ** Warning: (vsim-4014) No objects found matching ‘this’.
regarding $writememh
Does frame_out fill with all memory locations ? if not try to specify start address and end address.
$writememh(“out_frame.txt”,frame_out, , );
Yes, I have used the $display statement to view the memory frame_out. The data is displayed correctly.
I have tried using $writememh in the program block, in which case the memory contents are written into the file out_frame.txt correctly.
The same thing doesn’t work when used in environment class object. Does anyone know why this is happening?
Anuradha
In reply to kbkdec15:
Anuradha
As Dave mentioned in one of the other thread, making the variable static will work.
